Home > In Car Electronics > Cd player problem
Paratrev
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Cd player problem
Has anybody had "invalid disc" come up on the cd player screen, this happens whilst a shop bought music cd (not a copy) is playing, the player then freezes and tells you to eject the disc,
Does anyone have a similar problem
Thanks in advance
Post #563023 Fri Aug 10 2018 10:50pm
GodivaNige
England 2009 Range Rover Sport TDV8 HSE Buckingham Blue
You likely have dirt on the CD pick up lens.
Unfortunately, this isn’t some random fleck of dust that one of those cleaning CD’s with tiny brushes will shift, it will need a strip down and cleaning with some solvent on the end of a cotton bud. The dirt build up comes with years of dust getting in to your CD player, mixing with condensation on cold mornings and forming a sticky dirty layer on vital parts such as the pick up lens or laser lens.
Remove the unit and strip & clean is the way forward. Thumbs Up
Post #563027 Sat Aug 11 2018 4:28am
Paratrev
Thank you for your answer, I will give that a go at next opportunity and post the result, thanks again.
Post #563062 Sat Aug 11 2018 7:16pm
Paratrev
Well, took the stereo unit out and cleaned the lens unit which to be fair was clean, put it all back together and refitted.
Played about 4 tracks then froze again, says "invalid disc" the only way forward then is to eject the disc.
Any suggestions most welcome.
Post #563364 Thu Aug 16 2018 8:03pm
GodivaNige
If it was all clean inside, not just the lens and pickup, but I’m guessing you could also see the transport was clean too, then the likely outcome is a faulty unit. Could be time to bite the bullet and buy another one. Confused
Post #563369 Thu Aug 16 2018 8:52pm
Paratrev
It looked clean, nothing obvious, its almost as if the wrong type of cd like a playstation etc disc has been inserted to give the invalid disc message
I take it by transport you mean the spiral rod the laser runs along.
Thanks again for your input
Post #563382 Fri Aug 17 2018 6:59am
