Home > Tips & Tricks > 3.6TDV8 Airbox Mod |
Are the filters oiled like K&N filters? Can’t imagine the MAF sensors will thank you for it! 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Thu Jul 26 2018 8:41pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4332 |
Nor will the heatsoak from that big engine... |
Thu Jul 26 2018 9:09pm |
glennp123 Member Since: 04 Dec 2017 Location: n.ireland Posts: 36 |
We shall see, i notice a difference in the car already. Going to get 2 cold air feed pipes sorted from side and front of car, my mates a TIG'er. |
Thu Jul 26 2018 9:22pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8828 |
Looks like a solution looking for a problem... 2012 SDV6 - it's missing a couple of cylinders
Thu Jul 26 2018 9:37pm |
RRSV8 Member Since: 18 Mar 2018 Location: nottingham Posts: 56 |
Can any universal cone filters be used ?
Thu Aug 02 2018 3:04pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
Why would you do this? Poor air filtration, possible oil issues - a waste of money and possible future engine issues. 07MY RRS TDV6
Fri Aug 03 2018 3:22am |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
I did something like this years ago on a V8 RR cone filter and air scoop first bit of water I went through the jet of water hit the filter which got dragged into the engine. To add insult to injury I was dragged out by some friends in a Suzuki, something they reminded me about for a few years !
Fri Aug 03 2018 10:23am |
I'm guessing the OP won't be going anywhere that isn't covered in tarmac - certainly deep water won't be on his agenda.
Fri Aug 03 2018 11:16am |
Its tarmac only. So far so good.. theres no lag at all when taking off, just goes! MPG has went up so far by 1. Getting 25MPG now according to the computer. |
Mon Aug 06 2018 10:34pm |
As time goes by you will end up with glazed bores in your engine and those filters are pore a catching the fine particles that polish the bores.
Tue Aug 07 2018 3:37am |
So everyone with cone air filters end up with glazed bores is that what your saying? Is this just Turbo Diesel applications or Petrol turbos also? |
Fri Aug 10 2018 4:46pm |
Yes after a time - is a well known side effect of these things - not an issue on a race car as the engines get re built all the time but when used on your road car it will speed up wear in your engine as it allows very fine particles through causing cylinder bore glazing amongst other things - is a well known issue.
Sat Aug 11 2018 1:51am |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2834 |
its chav in the UK garry not bogan Another Pommie Bar Steward down under
Sat Aug 11 2018 7:48am |
daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 139 |
Hi
Sat Aug 11 2018 10:15am |
