Home > Maintenance & Modifications > Bluetooth Factory Kit Install ( HHHEEELLPP ) |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4779 |
i guess you have the optical fibre going thru the BT module. BT module has no power and this is why screen is stuck on logo and you have no tunes.
Sat Jul 21 2018 9:45pm |
wiggs Member Since: 27 Apr 2007 Location: Manchester Posts: 99 |
The VUB kit does not actually come with a Bluetooth module .. you’ll need one of those to plug in the 54 pin connector Bluetooth Exchange www.bluetoothexchange.co.uk |
Sat Jul 21 2018 9:46pm |
VUB kit has nothing to do with the fibre optic loop ..
Sat Jul 21 2018 9:48pm |
Kirbs Member Since: 21 Jul 2018 Location: Suffolk Posts: 13 |
thanks for the replies.
Sun Jul 22 2018 9:40am |
Unfortunately it doesn’t make any sense
Sun Jul 22 2018 9:59am |
thanks yes the kit has the module with it but i was informed that it needed the Nokia voice activated module also.
Sun Jul 22 2018 10:10am |
can anyone point me in the right direction, i think this kit must be for discovery.
Mon Jul 23 2018 8:10pm |
Do you have the picture (comic) instructions ?
Mon Jul 23 2018 8:52pm |
Hi Andy yes you are correct about the power supply and the wires into the original plug these are all in place
Mon Jul 23 2018 10:13pm |
Mon Jul 23 2018 10:14pm |
blank.
Mon Jul 23 2018 10:45pm |
Does this not plug into the square module that comes with the kit ? Otherwise, does it plug into the back of the head unit. I can't see the connector pins from that angle. I think the large LR radio connector should be unplugged and looped thru this accessory wiring and then back to the radio ? |
Mon Jul 23 2018 10:47pm |
End of plug showing pin arrangement
Tue Jul 24 2018 7:35am |
don't know sorry.
Tue Jul 24 2018 10:43am |
