Home > General > Alarm going off when dead locking ? |
ilard Member Since: 20 Aug 2010 Location: London Posts: 972 |
Not had this. The deadlocking does switch on additional alarm sensors, so it makes me think a sensor is damaged. Quite why a window replacement would trigger this I am not sure, unless there is a sensor in the door itself. Hopefully someone more technical can give their views. I hope you can resolve... I ALWAYS deadlock mine and that proved most useful one night when some scally decided to prise open the sunroof and explore inside... the alarm when crazy and they had to exit the way they came in. Without deadlocking it is my belief they could have simply opened a door and the alarm would have disarmed leaving them free to open the tailgate, steal the lights, yadee yadee yadee. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Thu Jul 12 2018 9:09pm |
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 |
Plugged diagnostics in and cleared all codes and seems to of fixed the problem. Will see if it's all ok over the next couple of days 2017 SVR. SVO Scafell grey Ebony interior
Fri Jul 13 2018 12:36am |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
I thought the double click/deadlock, deactivated interior sensors? When I had my alarm issue I was told to double click to deactivate interior alarms. Steve. |
Fri Jul 13 2018 10:21am |
PIG88 Member Since: 23 May 2018 Location: North of Watford Posts: 194 |
I think it’s the other way round - one click activates the door alarm but not the internal sensors (eg so that you can leave a dog in the car). Two clicks will also activate the deadlocks and internal alarm sensors. |
Fri Jul 13 2018 2:25pm |
I was mis informed then Steve. |
Fri Jul 13 2018 5:10pm |
james5599 Member Since: 14 Jun 2009 Location: london Posts: 325 |
Yeah dont deadlock anyone inside though. 2019 Svr and 2019 R35 GTR |
Fri Jul 13 2018 5:18pm |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
For mine, one click of the key fob "superlocks" it and activates the perimetric alarm, interior space protection and tilt sensor.
Fri Jul 13 2018 7:03pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4840 |
On a face-lift RRS1 press lock button once to Single Lock, twice to Double Lock, on a pre-facelift RRS1 for some reason it is the opposite, single press activates Super Locking. As Double Locking prevents doors from being opened from inside the vehicle, the door panel would need to be removed and electrical multi-plug dis-connected to remove/replace window glass is it possible while putting everything back together the did something to the actual lock connection or dislodged a wire. Only a suggestion or thought.
Fri Jul 13 2018 10:37pm |
Here’s the topix page on single/double locking for 2012MY. Probably different for other model years but this is how it was on our 2012 L320.
Fri Jul 13 2018 10:42pm |
All depends Steve. |
Sat Jul 14 2018 4:11pm |
Traffic wardens and nubile females are exceptions. But both only in the boot. 2019 Svr and 2019 R35 GTR |
Sat Jul 14 2018 7:05pm |
