Home > Maintenance & Modifications > Brakes - Indy or national chain? |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
IMHO, the warning tells you when they are knackered. Get the wheels off and have a look at the pad thickness and condition of the discs. 1.8mm is an MOT fail. Frankly I would change at about 3mm.
Tue Jul 10 2018 7:34am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2006 |
Some good Indy’s in Dorset
Tue Jul 10 2018 8:10am |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 |
I've just booked it into one of them for a look over. Merc C220 estate Sport AMG
Tue Jul 10 2018 8:42am |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
In my experience the brake warning system is useless. My rear driver side pads were metal on metal...no light. As far as getting them replaced, any garage can do that for you....except Kwik obviously. Steve. |
Tue Jul 10 2018 12:04pm |
scousefly Member Since: 24 Jan 2015 Location: sheffield Posts: 248 |
To do yourself, rears a little more difficult. If you don’t fancy trying yourself take to an Indy but never Kwikshit
Tue Jul 10 2018 12:09pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 746 |
The warning sensor wires are only fitted to one side of one caliper per axle. This of course means that if you have a sticking caliper or pad, which isn't sensor equipped, it may well wear to the disc before the warning light comes on. If everything is working well, and you don't do huge mileages between services, it should be OK. |
Tue Jul 10 2018 12:17pm |
I took it to A L Services who have diagnosed a stuck caliper (should be covered under warranty) and needs rear discs and pads. The stuck caliper is on the side without the sensor, hence no warning. Should be sorted out on Friday if the warranty company get their finger out and authorise the work.
Tue Jul 10 2018 6:11pm |
Steve. |
Tue Jul 10 2018 7:14pm |
Well that works great Steve. |
Tue Jul 10 2018 7:15pm |
Glad AL could help you
Wed Jul 11 2018 3:30pm |
yep, they're very close to me so if they do a good job they could get all my business
Wed Jul 11 2018 3:40pm |
All done and dusted. £499 total, about 1/2 of which is covered by the warranty, including all the labour. Genuine LR caliper AP discs and pads.
Sun Jul 15 2018 12:20pm |
I take it that was both sides...good price, almost the same as I paid for my rears Steve. |
Sun Jul 15 2018 1:37pm |
Caliper on one side and discs and pads on both sides Merc C220 estate Sport AMG
Sun Jul 15 2018 5:33pm |
