Home > Maintenance & Modifications > Suspension noise |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
Is it a creaking type noise? Mine has started doing this. Apparently it`s common in this hot dry weather. Get some silicone spray on the ARB bushes. Not done mine yet...... Steve. |
Thu Jul 05 2018 4:52pm |
Rusty Novice Member Since: 04 May 2018 Location: Staffordshire Posts: 34 |
Steve
Thu Jul 05 2018 5:13pm |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
Just put up with it till it rains, or drive it through a river. Mines the same since the hot weather arrived but disappears when the rain comes. It’s all to do with surface rust in the bushes. I lubed it with silicon spray and that lasted a week, but my indi says all is well and my car is a 2013 with 60000 miles. |
Thu Jul 05 2018 5:22pm |
I forgot to say well done for buying a RRS, I’m on my fifth LR and wouldn’t be without one.
Thu Jul 05 2018 5:28pm |
Thanks Phil
Thu Jul 05 2018 5:36pm |
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 |
As my ne ARB bushes done last yr by an Indy with oem parts so into dealer to be replaced under warranty |
Thu Jul 05 2018 5:46pm |
If you want to get at all the bushes then take the wheels off, otherwise get her up to off-road height, secure with axle stands and leave a door open to prevent inadvertent lowering. When you get under you can see all the potential “squeakers” and a good spray may well help. It may be the anti roll bar bushes or the suspension arm bushes. Try to identify whether its rear or front.
Thu Jul 05 2018 5:52pm |
Phil
Thu Jul 05 2018 6:19pm |
So you had new bushes and now your returning it back to the main dealer to have the same work carried out under warranty Is my understanding correct buddy? |
Thu Jul 05 2018 6:21pm |
Same age range as me then It`s also my first and last. I`ll be moving on soon Steve. |
Thu Jul 05 2018 8:26pm |
zaphod Member Since: 16 Jan 2015 Location: Liverpool Posts: 279 |
I have this exact problem - it's embarrassing - makes my Sport sound like an old banger. Only started happening the past couple of weeks so would fit with the dry weather thing.
Fri Jul 20 2018 1:22pm |
This will give you an idea of what to look for
Fri Jul 20 2018 3:36pm |
micknolan Member Since: 19 Apr 2017 Location: West Midlands Posts: 39 |
I have sprayed mine 2-3 cans £15 over a few days.
Fri Jul 20 2018 4:25pm |
Does get you down some days.Inmy case a 20k car.
Fri Jul 20 2018 4:28pm |
