Home > Technical > Air con problem? Strange one |
DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264 |
I’m no expert , but did they pressure test the system before re-gassing it ?
Sun Jul 01 2018 3:38pm |
ben_edwards30 Member Since: 08 Jun 2018 Location: Shropshire Posts: 20 |
I thought it would be a leak but the rear vent being cooler confused me a bit? |
Sun Jul 01 2018 3:58pm |
That is strange ??
Sun Jul 01 2018 4:51pm |
Had a similar problem with my other car a small Renault it took the air-con guy a while to find it was 2 small leaks so i would say get it checked it will more than likely be low gas |
Sun Jul 01 2018 7:41pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
Take it back as they have probably put a dye in it, then they can use the black light to find the leak. I think the cooler vent is probably a coincidence, try a thermometer on each one. 2012 5.0 SC AB
Sun Jul 01 2018 8:48pm |
