Home > General > Mirror dip + tyre pressure
Sham91
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Bonatti Grey
Do both side mirrors dip when you put it into reverse as only one mirror dips for me but I’m sure both used to on my other car
This one is a RRS tdv6 2010
And also what tyre pressure do you recommend for 22 inch tyres ..front and back Very Happy
Post #559208 Sun Jun 17 2018 2:35pm
Brit Plumber
Left mirror only dips and I run my 22s at the same pressure as the 20s which I think is recommended by most vendors. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #559210 Sun Jun 17 2018 2:56pm
Sham91
Thanksmate and 33psi all round?
Post #559212 Sun Jun 17 2018 3:04pm
gogsy1956
Both mirrors dip on mine and I keep at least 38psi in my 22's 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #559228 Sun Jun 17 2018 5:25pm
Sham91
Interesting... mine both used to dip but only one now
I’m wondering if there’s an option where you can actually select both to dip or only one?
Post #559229 Sun Jun 17 2018 6:36pm
Oldandconfused
2010 RRS, both mirrors will dip, but I have set them so that only the NS one actually moves (so I can see the kerb). From memory you have to turn the reverse mirror dip on in the menu and when in reverse, set them to where you want them-best check your hand book though Thumbs Up
Post #559231 Sun Jun 17 2018 7:04pm
Brit Plumber
Had a play with my mirrors today and found that both do adjust for reverse but my drivers side was just set at the same position for forward and back. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #559370 Tue Jun 19 2018 12:43pm
Cymruambyth
Wales
You can change the angle to suit when you reverse. Steve.
Post #559376 Tue Jun 19 2018 4:40pm
Brit Plumber
What threw me was that only my passenger moved in reverse. It never occurred to me that the previous owner had never set the drivers side to dip (probably didn’t need to as I’ve found). So apologies to the OP for my response (2nd down from top ) stating only the pass dipped. I’ve learnt something new (again). 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #559388 Tue Jun 19 2018 5:49pm
