Home > Technical > Rear window wiper
Dylan
England 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Rear window wiper
Hi my rear wiper stopped working but my washer jet is ok . Have checked motor seems fine but have no power getting to it . Could anyone advise
Thanks
Post #558954 Thu Jun 14 2018 5:50pm
the early models have a relay behind the left light. (inside)
check power there.
or wires get broken going into the tailgate
Post #558957 Thu Jun 14 2018 5:57pm
Dylan
Hi thank you for the reply my rrs is a 2010 facelift .the wiper was working then one day it didn't work then about 20 mins into journey it worked but then didn't work again
Post #558961 Thu Jun 14 2018 6:18pm
Brit Plumber
Still worth testing the wiring between body and boot. I had a problem with a BMW where the locks would lock on command but then unlock seconds later. I found that 2 wires had shorted to each other at the point the look hinged. I ended up replacing all the wires at that point as 2 more had split. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #558974 Thu Jun 14 2018 7:31pm
Dylan
Thanks for that I will have a look at the weekend
Post #558976 Thu Jun 14 2018 8:02pm
Dylan
I have had a diag tool on this and it says open circuit on relay but can anyone tell me the location of it
Post #562090 Fri Jul 27 2018 1:30am
Would appear to still be behind L/H trim panel in boot.
Description: Relay-Trailer-Rear wiper
Post #562091 Fri Jul 27 2018 3:00am
Dylan
Many thanks for that I will have a look
Post #562093 Fri Jul 27 2018 5:54am
Dylan
Hi all sorry for the delay . I finally managed to get my rear wiper working . The Venter shaft on motor was a bit tight so freed that and was a loose connection on relay so happy days . The relay was as you said behind left panel in boot. Thanks everyone for your help
Post #566688 Thu Oct 11 2018 3:12pm
Dylan
Sorry center shaft
Post #566689 Thu Oct 11 2018 3:13pm
