Home > General (L494) > Rear brake squeal
V8tdi
Wales 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Rear brake squeal
I have had a squeal from the rear brakes for a while but just recently it got really bad just stopping at traffic people would stare at you with the noise
Car has done 20k miles it has the brembo brakes
I took it to my dealer who said pads were down to 4.5mm but discs had a ridge and recommended they should be changed
Anyway long story short dealer wouldn’t cover under warranty but after some technical arguing (I worked for Ferodo for 10years) he agreed that there was a warranty bulitin on rear pad squeal
So I agreed to pay the discs and got the pads changed under warranty to what he said was updated material but I didn’t check the old material code so can’t 100% confirm that
The dealer acknowledged the fronts were a known issue but it took some discussion before he also admitted the rear pad had also a problem
Anyway all fixed and thankfully quiet again 👍 post is just for info for anyone who has similar issue
Post #558947 Thu Jun 14 2018 3:06pm
ozzievechi
I have a MY16 SDV8, also 20k miles, and the squeal is horrific.... so im guessing all I need to say is can you replace with the updated version front & rear and if they stutter just mention there is a TB out there for it?
Post #558950 Thu Jun 14 2018 4:10pm
V8tdi
I guess they will try to avoid the warranty like they did on mine but just push them there is lots of stuff on the forums it’s a common issue I think
Post #558953 Thu Jun 14 2018 4:47pm
IRBails
Australia
Brake squeel is about good brakes. This article from Porsche may help you understand that squeel is not a factor of function.
http://www.thedrive.com/watch-this/18096/p...this-video M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #558995 Thu Jun 14 2018 10:37pm
