Home > In Car Electronics > Advice Needed
OzzyRanger
Australia 2008 Range Rover Sport TDV6 S Bonatti Grey
Advice Needed
G'Day All,
On my 2008 RRS TDV6 I have a weird anomaly - intermittently when I switch off the engine, the park brake light and the stereo display will stay on for a couple of minutes during which time the remote fobs (both of them) will not lock or unlock the doors. Once the display and park brake lights turn off the fobs work as normal - any ideas on this?
Post #557712 Wed May 30 2018 3:03am
waynescott523
United Kingdom 2008 Range Rover Sport TDV8 HST Alaska White
Hi guys, I need your help I've bought a 2008 3.6 tdv8 the problem is the screens in the rear headrest are not working (no power at all) also on my navigation screen there is not a rear entertainment option as there should be.there is power in the CD unit under the seat. Any ideas what the problem might be before I have to call out an audio tech guy. Thanks in advance Wayne.
Post #558933 Thu Jun 14 2018 11:33am
Ozzy - Try a squirt of WD40 into the ignition key hole.
Post #558934 Thu Jun 14 2018 12:02pm
Would not advise WD40 in ignition barrel, use a Graphite Powder if it may be sticking as the WD40 will gum it up over time.
Post #558938 Thu Jun 14 2018 12:50pm
I've not known it gum up.
And it needs to get to the bottom
Post #558955 Thu Jun 14 2018 5:55pm
geoffsnook
[quote="waynescott523"]Hi guys, I need your help I've bought a 2008 3.6 tdv8 the problem is the screens in the rear headrest are not working (no power at all) also on my navigation screen there is not a rear entertainment option as there should be.there is power in the CD unit under the seat. Any ideas what the problem might be before I have to call out an audio tech guy. Thanks in advance Wayne.[/qu
It would be helpful if we new what car these screens were in and are they aftermarket or factory fitted if your not sure then post some pics and start a new thread about it Thumbs Up
Post #558967 Thu Jun 14 2018 7:01pm
Scrumpy
I used to be a locksmith and I agree with Col. We always used dry graphite powder which will get to the bottom as it's very frictionless (same as rubbing a graphite pencil on a squeaky door hinge to silence it).
Any wet oil can attract dirt and dust to stick to it, eventually wearing out the internal components of the lock barrel. 2016 RRS SVR Estoril Blue
Post #558979 Thu Jun 14 2018 8:40pm
