Home > My Range Rover Sport > My First RRS |
beerguzzler Member Since: 01 Apr 2018 Location: swindon Posts: 28 |
Hi All,
Mon Jun 11 2018 9:56am |
Hi.
Mon Jun 11 2018 12:22pm |
That’s no enough when running I think you need more maybe your alternater is on the way out but someone will come along and confirm |
Mon Jun 11 2018 12:33pm |
Thanks |
Mon Jun 11 2018 12:39pm |
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 |
Like either battery or alternator. I would start with a new battery |
Mon Jun 11 2018 1:08pm |
Thanks.
Mon Jun 11 2018 1:17pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8827 |
Probably put a new battery in so that it would work nicely when being test driven.
Mon Jun 11 2018 2:45pm |
The 12.6 was engine just turned off. I will leave it overnight and test in morning. I am afraid she doesn't get 24 hrs rest so i will see what it is after about 14 hrs. I will check all earth leads tomorrow and see how it goes.
Mon Jun 11 2018 3:00pm |
See what it kicks out with all the electrics on lights air con heated seats screens etc |
Mon Jun 11 2018 6:07pm |
So i checked this morning after it stood all night and it read 12.2v then drove for an hour and turned everything on, seats lights air con etc and it read 12.2v while running. That not enough?
Tue Jun 12 2018 11:14am |
No mine normally runs at about 13.8-14.2 but mine is petrol so you may have an issue there do make sure your earths are all good first |
Tue Jun 12 2018 3:02pm |
12.2V when the battery has been left standing is a bit low really. If it's at 12.2V after an hour of engine running and with stuff turned on then that suggests the alternator is poorly. 2012 SDV6 - it's missing a couple of cylinders
Tue Jun 12 2018 4:13pm |
Ok. So new alternator. I couldn't find any loose earths. I have been looking at alternators and i can see some with or without "ace" whats that? How do i know which one to get?
Wed Jun 13 2018 12:00am |
If it has a small bottle under the bonnet with a yellow cap and a car on it with an arrow left and right then your car has ACE it’s active cornering enhancement I think also you will.have a yellow picture on the dash board that lights up on start up and then should go out the picture is pretty much the same |
Wed Jun 13 2018 5:07am |
