Home > Faults & Fixes > Slow Acceleration form standstill then Surge !
mrluke
Hi got a 2012 RRS , I have noticed ( mostly when cold) if i get to a junction and try and pull away ( as a speed so i dont get hit ) the car seems very slow and even though ive kept the same amount of accelerator pedal pushed down i then suddenly get a surge .
Happens in both Sport and Normal and im unsure if this is a normal characteristic of this car ?
Any one else have this same problem ?
Thanks
Luke
Post #558467 Fri Jun 08 2018 12:34pm
Brit Plumber
I assume it’s a 3.0 SDV6? 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #558485 Fri Jun 08 2018 3:31pm
mrluke
Indeed it is Very Happy
Post #558487 Fri Jun 08 2018 3:34pm
hoppy_70
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Rimini Red
Yes it’s characteristic of the car and super annoying when pulling out into busy traffic. A remap would fix it... Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Range Rover sport HSE Dynamic P400e Silver
Range Rover Sport 3.0 SDV6 HSE Dynamic 2016 MY
Range Rover sport 3.6tdv8HSE 2007 Gone
Range Rover sport 2.7tdv6SE 2005 Gone
Range Rover sport 2.7tdv6SE 2007 honey
Range rover Vogue 2005 4.4 - GONE and missed
BMW 535d M sport 2006 - GONE not as missed
BMW X5 4.4 2004 sport - GONE
Post #558501 Fri Jun 08 2018 6:50pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
My sdv6 was like this at first. The old "roundabout" hesitation was the worst. Do you hold your breath and go for it or just try to time your arrival so as not to stop ?
Some say it is because from stop it moves off in second gear, that is to say, you have to manually select first on your flappy paddles. I can only say that when I had my remap done ages ago by Alive that it cured this problem altogether. And took bhp to 306 and a good slug of extra torque as well. No reliability issues 40k and 2 years later. BAS also come highly recommended on here.
Only downside is certainly at the time a 2012 my could not be remapped by obd port, it was an ecu out job. I took mine to Alive at Louth and they did it while I waited, around 3 hours or so as I recall, but they have fitting agents who may be able to do this if it is still ecu out and not doable via obd.
Post #558544 Sat Jun 09 2018 8:32am
Smarttech
My 62 plate sdv6 is like this and from what I have read that is normal unless it had a remap.
Odd part is, went back to main dealer for mot and health check which it pass with nothing advised on mot or health check but any hesitation was gone from standstill and it seemed to be in the right gear at the right time constantly with no delay in power.
This was in January and the car has now reverted back to hesitation when trying to pull away in a hurry so what did they do or reset that fixed it if only for a few months.
I will remap mine once out of the warranty as I've heard it transforms the way they drive. 2017 SVR. SVO Scafell grey Ebony interior
2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone
Post #558545 Sat Jun 09 2018 8:58am
Maca
my 2015 Range rover Td6 i had remapped
goes like a bat outa' now BUT i have 3 new probs.
1
surge on a delayed responce throttle.
2
Suspension Fault on screen no light on button.
3
power disapears sometimes only way to get it back is "kick down"
Post #561145 Tue Jul 10 2018 9:21pm
Smarttech
Td6 ? Are we talking about a Sdv6 sport as TD6 was the old straight 6 they used in a vogue.
I think the question here is who did the remap? 2017 SVR. SVO Scafell grey Ebony interior
Post #561148 Tue Jul 10 2018 9:25pm
Lindab
Mine does this as well. You think you have plenty time at roundabouts, Very Happy then suddenly the car coming round is nearly on top of you, Censored then the power kicks in, very disconcerting. I welcome any info on a fix.
Post #561176 Wed Jul 11 2018 10:30am
Father Jack
See my post above.
Post #561181 Wed Jul 11 2018 11:26am
mrluke
Was the remap specifically aimed at this problem ? or was it done for general increase in power ?
Post #561182 Wed Jul 11 2018 11:30am
Father Jack
It was aimed at better general driveability and at least the ability for better mpg. Power and torque increases are relatively modest at circa 20 percent, and merely take the mk1 to broadly the same outputs as mk2, so no concerns about overstressing engine, gearbox or driveline components.
To answer your specific question I did not do this solely to cure roundabout roulette but it has dealt with that for me and I seldom need to use S mode or paddles except if I am in a terrific hurry. D mode with dynamic mode for twisty bits almost always does it (90 percent plus of the time) now.
Post #561185 Wed Jul 11 2018 12:21pm
shepp
My 2012 suffered horrendous delay, until I had a full service and used wynns extreme clean. Seems my injectors were bunged up.
https://www.amazon.co.uk/Wynns-Diesel-Clea...B00TYF1EUC MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #561221 Wed Jul 11 2018 9:11pm
Father Jack
I run the wynns through a couple of times a year and generally dose with millers each fill up.
Post #561223 Wed Jul 11 2018 9:12pm
