Home > Faults & Fixes > steering vibration
dieselwoofer
steering vibration
Any ideas to the cause of steering vibration at 70-80mph. After 3 wheel balances its much better but not perfect
ive had the suspension inspected by land rover and they can't find any faults?
the only issue that came up was brake judder at 70+ mph.... coincidence ?
Whats your thoughts on this, can a brake disk cause vibration even if the brakes are not being used
Thanks
Post #557103 Mon May 21 2018 8:44pm
Brit Plumber
I get a intermittent vibration through my steering wheel at the same speeds. Always seams to happen in the first 5 minutes of starting then goes away. I need to check my brakes and see if I’ve got one dragging a little. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #557109 Mon May 21 2018 9:11pm
dieselwoofer
It’s going back to the garage on weds as it’s still under warranty
I’m hoping they will change the discs and inspect the calipers
I’ll see how that goes 👍
Post #557114 Mon May 21 2018 11:13pm
IRBails
Australia
Re: steering vibration
Thanks
So is this a 1980 RRS no car details so how can we help? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #557116 Mon May 21 2018 11:28pm
Brit Plumber
I’ve just noticed that this new forum format has removed all my details. Is it just my screen that has this new format? 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #557117 Mon May 21 2018 11:46pm
Brit Plumber
A screen shot of what I now see. And no obvious way to edit a post either.
Sorted now, I didn’t realise the forum changed a while ago and my phone was using the desktop site which I prefer. So I’ve switched back to the desktop style and all is good now. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #557118 Mon May 21 2018 11:48pm
dieselwoofer
Same the mobile version is a bit basic. 2011 RRS facelift
Post #557130 Tue May 22 2018 7:43am
IRBails
Australia
OK your model has the same brakes as mine I believe. I had a lot of issues of vibration on brake application which turned out to be the pad material used by Range rover, it seems in the flat land of Oz with little traffic the brakes would not get to he right temps and brake material would adhere to the rotors. I fixed by changing pads to Red Stuff pads, ECB I think. All good now. I also get some slight vibes first thing in when the outside temp is low, goes after a kilometer. I put this down to a standing flat spot in he tyres. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #557132 Tue May 22 2018 8:12am
ondafly
Ireland 2007 Range Rover Sport TDV6 HSE Java Black
make sure the tire pressures are correct - I had a similar issue at speed even after a wheel balancing, turned out the front left tire was down on pressure with the rest.
Post #557262 Thu May 24 2018 10:12am
dieselwoofer
Still going around in circles on this
The garage has been excellent, I sent the car back under warranty. They put new pads, discs and callipers on the front, rotated the wheels, full alignment and balance and its a lot better. But... on certain road surfaces it slightly comes back
what to do next? 2011 RRS facelift
Post #557666 Tue May 29 2018 3:10pm
dieselwoofer
[quote="IRBails"][quote="Brit Plumber"]A screen shot of what I now see. And no obvious way to edit a post either.
[img:224:400]http://www.rrsport.co.uk/gallery/albums/userpics/25534/normal_4C9AC9BA-746C-4C61-B30E-59B5A876A3D0.png[/img]
Sorted now, I didn’t realise the forum changed a while ago and my phone was using the desktop site which I prefer. So I’ve switched back to the desktop style and all is good now.[/quote]
OK your model has the same brakes as mine I believe. I had a lot of issues of vibration on brake application which turned out to be the pad material used by Range rover, it seems in the flat land of Oz with little traffic the brakes would not get to he right temps and brake material would adhere to the rotors. I fixed by changing pads to Red Stuff pads, ECB I think. All good now. I also get some slight vibes first thing in when the outside temp is low, goes after a kilometer. I put this down to a standing flat spot in he tyres.[/quote]
tyres is all I have left to try before getting into bigger costs 2011 RRS facelift
Post #557667 Tue May 29 2018 3:11pm
