Home > General > Best engine |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8834 |
Each engine has its own issues. The 3 litre diesels can have a crankshaft issue, the TDV8 can have turbo issues. Which diesel is having cracked blocks? 2012 SDV6 - it's missing a couple of cylinders
Mon May 28 2018 3:52pm |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1121 |
which problems, and on the L320 or L494? whatever you do, avoid the 3.0 diesel -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Mon May 28 2018 4:51pm |
I thought there was less issue's with the 5.0 sc |
Mon May 28 2018 5:04pm |
Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163 |
Does that go for the sdv6 also |
Mon May 28 2018 5:40pm |
kismet110 Member Since: 09 Oct 2010 Location: London Posts: 382 |
The 5.0 S/C is relatively problem-free and a superb engine to boot. |
Mon May 28 2018 5:46pm |
SDV6 can have crank problems too but in the minority but if it goes it's still a new crank |
Mon May 28 2018 6:00pm |
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 |
3.0 since when My 3.0 L320 literally hassle free and anything I did have issues with was covered by the 2 yr used car warranty. So a bit liberal with that assumption, 3.0 litres are excellent in my opinion |
Mon May 28 2018 6:11pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4779 |
if you are happy with petrol stick to it.
Mon May 28 2018 8:05pm |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
I have owned three 3Ltr V6s, one TDV6 and 2SDV6 and covered about 75000 miles in them and never had a single engine problem. |
Mon May 28 2018 10:04pm |
I collected 5.0 s/c today and the performance is outstanding for such a heavy motor
Thu Jun 07 2018 11:30pm |
I know what you mean, Cosmo.
Fri Jun 08 2018 7:53am |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
I took out my friends son in mine last weekend and he thinks it’s similar performance to his mums Audi SQ5 but I’m convinced it’s quicker. 2012 5.0 SC AB
Fri Jun 08 2018 8:55am |
