Home > Maintenance & Modifications > Different height RRS
dieselwoofer
I keep seeing lower RRSports. Mine on normal height, is there lowering kits available?
Post #557115 Mon May 21 2018 10:15pm
garrycol
Australia
There are various means of lowering - replacing the height rods, fitting LLAMS height adjustment system, reprogramme height with something like a Gap tool.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #557121 Tue May 22 2018 12:11am
dieselwoofer
These look like standard older cars. does the air suspension sag over time? :wink: 2011 RRS facelift
Post #557314 Thu May 24 2018 9:02pm
d-9
Generally the air either works or drops, they don't ride lower (because the height sensing is separate to the airbags).
Post #557321 Thu May 24 2018 10:15pm
garrycol
Australia
dieselwoofer wrote:
These look like standard older cars. does the air suspension sag over time? Wink
No it does not sag over time - it is deliberate using something as I described above.
I run my car at 1" lower than onroad height by using my LLAMs height adjust system.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #557328 Fri May 25 2018 2:17am
d-9
Does it handle any better an inch lower, or is it just for looks?
Post #557358 Fri May 25 2018 10:40am
garrycol
Australia
It drives better and is easier to get in and out of.
I dont think it makes the car look better - the proportions are not right. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #557368 Fri May 25 2018 12:14pm
mlines
Driving or parked?
Driving you need to reprogramme the suspension using a programmer or dongle.
Parked - Use the "Access Height" setting on the suspension on older RRS and "Automatic Access Height" on new shape RRS 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #557372 Fri May 25 2018 12:21pm
CornishRob
United Kingdom 2006 Range Rover Sport TDV6 HSE Sumatra Black
I have a GAP tool, and lowered mine, not by too much I thought, but it lost it's magic carpet ride. When I re-set it to standard, it was sooo much nicer. Not something I'd do again, even for looks.
Post #559724 Sun Jun 24 2018 3:48pm
