Home > Maintenance & Modifications > Possible air leak? |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
Is your air compressor running at the same time? If not, I doubt it’s a leak, maybe something moving which sounds like a leak. 2012 5.0 SC AB
Fri May 18 2018 10:35am |
LJRH Member Since: 22 Apr 2016 Location: Hertfordshire Posts: 209 |
No my mechanic just noticed it when the car was sitting still on idle. We were actually trying to work out what the exhaust rattle was Noisy black one |
Fri May 18 2018 10:37am |
The valve block for the front suspension is in the offside front wheel arch so it will more than likely be the system self levelling. Mine usually hisses and clicks a couple of times after I park up. |
Fri May 18 2018 12:07pm |
Thanks guys Noisy black one |
Sat May 19 2018 11:19am |
