Home > General (L494) > 20, 21 or 22 inch wheels? |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 |
Is there any ride/ comfort advantages to wheel size? My car currently has 22’s and I wonder if it might have a better feel to it if they weren’t so big. I also prefer some of the 21 inch styles so may change anyway.
Thu May 17 2018 9:58pm |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 863 |
I have 20 inch for one reason, the RRS is a 4WD and I want to go bush. If you have purchased for any other reason then it is all about other functions and looks I think. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Thu May 17 2018 11:58pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
I have 20 inch on mine shod with 40 profile tyres. Bearing in mind the shambles the councils have left the road network in, with potholes everywhere, I find the ride a bit too harsh. Was toying with the idea of trying some 19 inch winter wheels at some point but for various reasons have not yet got around to trying that. I am also considering changing the profile on my next set of tyres from 40 to 45 which may help slightly. This all based on comments from other contributors to this forum and not from my own experience.
Fri May 18 2018 7:42am |
Its not all about the size of the wheel,,its the profile of the tyre,i was running 285/35r22's on my RRS1 & the ride was fairly hard,as soon as I got my14 RRS I kept the 22" wheels but went to 295/40r22 tyres & it improved the ride.If you go for 22's on a RRS1 i suggest you go for 275/40r22,,ive just fitted my old RRS2 alloys to a friends RRS1 with that size & he says its a better ride than his 275/40r20's that he had on it before.If you are considering 21's then you need 275/45r21.
Fri May 18 2018 7:53am |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1121 |
Thanks Andy, what would you recommend for a 20" rim? --
Fri May 18 2018 8:09am |
275/45r20 will make the ride better & they also fill the arches better.
Fri May 18 2018 9:16am |
Hmm, but that is a smaller sidewall, so a bit worse for offroading? --
Fri May 18 2018 10:34am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8834 |
Naks, if you can fit them, go with 19 inch wheels for off roading. That will give you a deeper sidewall which is better away from tarmac. 2012 SDV6 - it's missing a couple of cylinders
Fri May 18 2018 11:45am |
Unfortunately the SCV8 can't take 19" rims, otherwise I would aim for these --
Fri May 18 2018 12:22pm |
I’m afraid you can’t really go any higher than 45’s if you fit 20’s,,which RRS have you a 320 or 494,,if it’s 320 then you can fit 19’s but only a certain LR wheel,,I remember a member on here bought some 19’s that were original LR but didn’t fit so you’ll have to research which ones fit,,then you can go 255/55r19’s or probably 60 profile. Andy Andy. 21 Ford Ranger Gone but not forgotten Focus RS Red Edition 2015 RRS AB Fuji. 2014 RRS SC Santorini 2016 VW Amarok 2014 RRS AB Fuji 2012 RRS Red Edition Fuji 2015 Nissan Navara 2012 RRS SE Santorini 2008 RRS White 2007 RRS Santorino |
Fri May 18 2018 4:28pm |
I'm busy shopping for an L494, and getting the dealer to fit 20" as part of the deal. --
Fri May 18 2018 4:31pm |
If you are getting a l494 then I’m sure you will be able to fit 275/50r20 as they are near enough same rolling radius as the 275/45r21’s that they fit those standard to the 494
Fri May 18 2018 4:40pm |
Chris-52 Member Since: 19 May 2016 Location: Surrey Posts: 36 |
I went for 20” on my AB. The ride is great, it goes round corners great and there is zero chance of kerbing the rims. I also preferred the look of the 20” and I think the bigger wheels look too ornate. |
Fri May 18 2018 5:40pm |
If 20 inches gets you in the bush then count me in Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY Range Rover sport HSE Dynamic P400e Silver Range Rover Sport 3.0 SDV6 HSE Dynamic 2016 MY Range Rover sport 3.6tdv8HSE 2007 Gone Range Rover sport 2.7tdv6SE 2005 Gone Range Rover sport 2.7tdv6SE 2007 honey Range rover Vogue 2005 4.4 - GONE and missed BMW 535d M sport 2006 - GONE not as missed BMW X5 4.4 2004 sport - GONE |
Fri May 18 2018 9:46pm |
