Home > Faults & Fixes > Suspension possible leak
Philhudd
Hi all i am new to the Forum
I have a 2006 Range Rover sport, don’t tend to drive much in the week as i have a work van, however when left a couple ofdays the rear suspension on passenger side drops, i always park it and leave in access mode, when i turn the key on there isa red flashing line on the 4x4 information screen, within 10 seconds it levels itself and all is fine, just worried it may get worse
Wheredo i start??
Post #556538 Tue May 15 2018 7:09pm
geoffsnook
Check for a leak with soapy water when its switched off the airbag may have a slight leak Thumbs Up
Post #556541 Tue May 15 2018 7:13pm
Philhudd
Thanks will do, it takes days to lower that’s the strange thing
Do you know what the little red flashing line means above the wheels on the 4x4 info display?
Post #556542 Tue May 15 2018 7:23pm
geoffsnook
It tells you there is a problem on that wheel with the height you may have a leak or the height sensor may be faulty but If its If it’s taking its time a air leak is quite likely and if that slow may also be a pain to find Thumbs Up
Post #556543 Tue May 15 2018 7:35pm
Philhudd
Great thanks for the response, I think I’ll leave it till it gets worse then
I assume it will need new suspension if it’s leaking, no way of fixing?
Post #556544 Tue May 15 2018 7:38pm
geoffsnook
Depends if it’s an air bag then new if it’s a seal then you know how long is a piece of string Rolling with laughter
Post #556549 Tue May 15 2018 8:06pm
Socast
If there is a leak you want to fix it sooner rather than later. Unless of course you want to replace your compressor too Rolling with laughter
Post #556708 Thu May 17 2018 11:30am
