Home > Wheels & Tyres > I think my speedo is out, help calculating correction please |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
Does anyone know? Cheers Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
Mon May 14 2018 4:52am |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 |
You could send pat an email @ gap diagnostics đź‘Ť
Mon May 14 2018 6:13am |
Thanks - I just thought someone on here would know if it is possible.
Mon May 14 2018 7:25am |
In the UK if you think you have an error in your speedo then you can easily check it using the verge/ hard shoulder markers on any UK motorway and most major A roads in England.
Mon May 14 2018 8:29am |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 |
that would explain why I ran my kayak aground in the Solent at the weekend (my excuse and I'm sticking to it)! Merc C220 estate Sport AMG
Mon May 14 2018 11:49am |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
They can’t just turn off GPS, it doesn’t work like that. They would more likely retain the relevant crypto key from those they don’t want to cheat. Aircraft such as Typhoon and Tornado need valid Crypto to actually work and if it’s not a valid key, the AC won’t fly. 2012 5.0 SC AB
Mon May 14 2018 4:56pm |
They can and do which is one reason why the EU wants its own system - I’m a day to user commercially and we have received numerous navigation warnings over the last month advising. They only switch it off in set locations, or rather they remove 8 or 12 channels that renders the accuracy so wildly out it is unusable....... USA did the same in the Red Sea a couple of years ago when they were assisting the Saudis with Yemen and further back when they were sending the cruise missiles into Baghdad we had never ending alarms on or ingtegrated bridge systems 24/7 for months when operating in the Middle East. It is one reason why I have GLONASS availability now as well on my ECDIS systems onboard - too many shipboard systems rely on satellite navigation of one nationality or another. China has its own system and India is also developing one for the Indian Coast regions. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon May 14 2018 7:33pm |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
As Tim says, they can - GPS jamming get's advertised when naval exercises are being carried out.
Mon May 14 2018 8:35pm |
land rover must have bought a huge batch of sat navs with the channel options permanently removed |
Mon May 14 2018 8:47pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4816 |
I compared my speedo to several of the 30mph smiley face speed warning signs that flash the speed up and found at 32mph it never triggered them at 33mph it did. Also compared it to the one's that show your speed when approaching them as well and found it spot on, that was after fitting 275/45 x 21" wheels, so figured the speedo was accurate enough not to get a ticket. If you want a more accurate reading you could always try driving through a few fixed speed cameras at a specific speed then when you get the tickets you will know what speed you were actually doing.
Mon May 14 2018 9:35pm |
Jamming is different to switching it off, switching it off is a massive problem and very rarely happens. They can restrict access by changing the crypto for one that has limited issue. military GPS is far more accurate than anything civilian or commercial and by turning it off, it turns off more than just GPS, there is other stuff that runs hand in hand with it. The exercise quoted is one I’ve taken part in a number of times and we always had fully crypto keys, like I say, with out it, the Typhoon won’t work well at all. 2012 5.0 SC AB Mods: TPMS Genuine LR DRLs Remote Boot close from key fob 2016 Discovery 4 Mirrors AKA RRS2 2014 L405 Surround Camera retro fit (WIP) 2013 RRS Dual View Screen fit (Complete) 2016 LR4 RSE 2014 LR4 Homelink 2016 FFRR Electrochromatic Wing Mirror Glass 70 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Mon May 14 2018 9:44pm |
Stuff that runs in conjunction with it includes mobile phone networks, street lighting, traffic light system timers and a host of embedded bits in equipment that require super accurate timing, that you never thought needed GPS! I have no objection to loss of accuracy provided we are told about it (which mostly professional user are) - after all I was trained and spent a lot of my profession in the time when we had to use a sextant (or Decca Navigation in coastal waters) to find our position and that didn’t always work out error free and someone often switched off the sun by sending clouds over at the critical moment - loss of GPS signals is nothing new, just that it has an effect on far more people than it used to. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tue May 15 2018 8:05am |
grey17 Member Since: 18 Jul 2016 Location: London Posts: 62 |
Hi Garry. Yes, you can adjust the tyre size in the RRS1. I asked Land Rover and they said no problem, they just need to plug it in and correct it on the computer. G |
Thu May 17 2018 5:50pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
Yes, I have the same. For the car to travel at 70 mph I have to set the cruise at about 77mph. But the speedo appears to be more or less accurate. Weird! Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Fri May 18 2018 7:22am |
