Home > General > suspension will raise when cooled ..Help
stebenny
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Hi All Had a new air compressor pump fitted a month ago all was fine until a few days ago when the suspension went into low mode and wont raise when i press the button to raise i get this message "suspension will raise when cooled" although the car has not moved all night I get a message saying slow down our car will raise but it wont,,, Is it safe to drive untill i get it sorted Thanks in advance
Post #556320 Sun May 13 2018 8:36am
Disco_Mikey
Either a faulty temp sensor on the compressor or a wiring issue to said sensor
Post #556337 Sun May 13 2018 2:55pm
stebenny
As always thank you, Is it safe to drive till i can get it looked at
Post #556344 Sun May 13 2018 5:27pm
Socast
If the car is lowering over night it may be that you have an air leak and the compressor has burned itself out trying to maintain pressure. Does the temp warning come on straight away or after 5 mins or so ?
It's safe to drive on the bump stops but it won't do your tyres any good.
Post #556428 Mon May 14 2018 3:57pm
