Home > Tips & Tricks > Heat gun to bring back the black
Wayneclarke
Has anyone tried a heat gun to bring back the black on the scuttle panel under the front windscreen ?? Seen a few videos that this is a good way to black back to black
Post #552754 Sat Mar 31 2018 6:14am
david007
United Kingdom 2011 Range Rover Sport SDV6 SE Vesuvius Orange
I’ve never heard of this before so just had a Google to find out a bit more, from what I can see it does seem to work, however it doesn’t appear to last that much longer than using a trim dressing, also some people seem to say it’s quite hard to get an even finish/colour across the whole trim assembly. So I don’t think I personally would try it, but if you do I'd be interested in seeing the results. If worst came to worst and the panel was damaged I think a new one is only about £60 so it wouldn't be the end of the world if you needed to replace it.
Post #552760 Sat Mar 31 2018 7:24am
Tyrefitter
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
Don’t bother unless your doing it to sell a vehicle as it only lasts a few weeks then it’s back to light grey,I tried it.Im yet to find something that lasts.
Andy. Andy.
2014 RRS SC santorino,coris roof.
2014 Evoque D-Lux Fuji
Previous motor.
2016 VW Amarok Highline,candy white
2014 RRS AB FUJI
2012 RRS Dynamic red edition Fuji
2012 RRS SE santorino
2015 Navara White
2008 RRS white TDV8
2007 RRS black TDV8
2002 RR Vogue
1996 P38 2.5 HSE.
Post #552761 Sat Mar 31 2018 7:27am
Wayneclarke
Yeah I’m the same keep trying different things it just looks so tatty being that dull grey, perhaps I should just buy a new one
Post #552765 Sat Mar 31 2018 8:00am
GodivaNige
England 2009 Range Rover Sport TDV8 HSE Buckingham Blue
Search for ‘Wipe New’
Incredible product which lasts and lasts. I applied this to all exterior black plastics on my car about a year ago and they still look perfect. Word of warning though, apply only on warm days and if your car is kept outdoors, when there is no chance of rain for at least two days. Best if you can let the product cure (which takes at least 24 hours depending on how warm your car is) with the car under cover in a garage.
I’m fairly sure there is another similar product by a more well know brand but can’t remember what it is.
Also, wear gloves. It’s not good for your skin Thumbs Up A pair of latex gloves is supplied in the kit.
Post #552767 Sat Mar 31 2018 8:28am
Cymruambyth
Wales
I bought some Aerospace 303 trim restorer as I really rate the 303 protectant.....I`ve not used it yet but it seems good stuff. Loads of youtube vids.
https://www.amazon.com/303-30326-Automotiv...merReviews Steve.
Post #552793 Sat Mar 31 2018 12:11pm
Lindab
Gtechniq C4 trim restorer, brilliant easy to apply, a little goes a long way as you get a tiny bottle but it is more than enough to do all the trim on a Range Rover. Lasts for about a year
Post #552848 Sat Mar 31 2018 9:59pm
GodivaNige
That’s the one, works the same way as Wipe New, a permanent chemical reaction. Again, takes a long time to go off and any rain will result in streaking, but applied well it makes an almost permanent restore.
Post #552853 Sat Mar 31 2018 10:27pm
Brit Plumber
I use anything with a high silicone content, the plastic will absorb it and you need to apply it until it stops absorbing the stuff and wipe off the excess. I think the heat gun method brings the silicone to the surface which in effect is taking more from within the structure. 2012MY RRS 5.0 Supercharged Autobiography (Current)
67 plate Focus ST Line (Current)
09 Mondeo 2.2 Titanium X Sport (Current)
02 Ford Focus TDCI (Brilliant car sadly scrapped)
99 BMW M3GTII (Amazing car, written off By a Fiat)
Post #552938 Mon Apr 02 2018 9:28am
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
This may sound silly, I used Peanut Butter Smooth. I think it is the oil in it that does the job Cool itisme
Post #552969 Mon Apr 02 2018 4:12pm
HughN
United Kingdom 2006 Range Rover Sport TDV6 HSE Zambezi Silver
+1 Thumbs Up "I am never content until I have constructed a model of the subject I am studying. If I succeed in making one, I understand; otherwise I do not" - Lord Kelvin
'06 RRS 2.7 TDV6 HSE
'14 D4 3.0 TDV6 HSE
Disco II Td5 - gone (went to Africa)
Disco I V8 - gone (no engine, brakes or power-steering but towed away by a Suzuki Jimny on a 6ft rope)
Disco I V8 - gone
[Plus two Freelanders I'd rather forget but my wife liked]
Post #553016 Tue Apr 03 2018 6:08am
grey17
United Kingdom 2009 Range Rover Sport TDV8 HSE Stornoway Grey
You can clean most of it off with steel wool kept wet with soapy water prior to using a back to black product. (I'm talking only about the scuttle panel at the bottom of the windscreen).
Afterwards, I used this product which is quite simply amazing!
I cleaned mine 18 months ago and its still black!
G
Post #556144 Thu May 10 2018 3:05pm
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
I had mine replaced under warranty. Not only did it go grey/white, the surface deteriorated so badly you could scratch it if you used your finger nail lightly.
Post #557353 Fri May 25 2018 9:15am
d-9
Try wurth bumper dye. Im not a fan of the heatgun method as after a few years you can have very patchy bumpers.
Post #557357 Fri May 25 2018 10:39am
