Home > My Range Rover Sport > Had my alloys refurbished and now gunmetal grey.
Jampot1979
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
Had the alloys refurbished and colour changed to gunmetal grey. Totally changes the look.
Post #555801 Fri May 04 2018 7:16pm
kismet110
Look good! What colour were they before?
Post #555803 Fri May 04 2018 7:18pm
Jampot1979
They were the standard silver.
Post #555805 Fri May 04 2018 7:39pm
Pinnacle
Is that an after market suspension. How you get your RRS to go so low?. I can't get my that low in access mode.
Post #555812 Fri May 04 2018 8:53pm
Jampot1979
Standard suspension... Maybe the pics make it look lower. 🙂
Post #555815 Fri May 04 2018 9:42pm
Pinnacle
Maybe it's the autobiography bumpers that makes it look lower.
Post #555836 Sat May 05 2018 8:34am
Cymruambyth
Wales
Looks great. IT`s an HST isn`t it, not AB?
Mine sits as low as that on access. Maybe larger alloys trick the mind Thumbs Up Steve.
Post #555847 Sat May 05 2018 3:19pm
Pinnacle
Sometimes when I try to put mine in access it says suspension extended mode and starts rising again.
Post #555870 Sat May 05 2018 10:07pm
Tim in Scotland
It will try to go extended mode if the under car sensor detects something that triggers the suspension ECU think the car will bottom out or get hung up. Have you checked under the car that there isn’t something loose or have you driven over something and dislodged the sensor? Or have you had some work done on the suspension - even had new wheels/ tyres fitted recently, that might have disturbed the level detectors? 2018 Melting Silver Mini Countryman PHEV - a test car before Seeing if I could go to totally Petrol/Diesel free motoring
Post #555877 Sun May 06 2018 7:19am
Jampot1979
Yep. It's an HST Thumbs Up
Post #555897 Sun May 06 2018 11:21am
Cymruambyth
Wales
Are those 20`s? Steve.
Post #555919 Sun May 06 2018 8:57pm
Jampot1979
Yep. 20's.
Post #555921 Sun May 06 2018 9:49pm
Cymruambyth
Wales
Thumbs Up Steve.
Post #555927 Mon May 07 2018 7:14am
Pinnacle
Yeah I put 22" on.
but it did that with the 20"'s on as well.
Post #555947 Mon May 07 2018 4:59pm
airc909
United Kingdom 2005 Range Rover Sport TDV6 SE Siberian Silver
those tyres look chunky Thumbs Up
are they 275 45 20
Post #557918 Fri Jun 01 2018 2:52pm
