Home > Maintenance & Modifications > Parking sensors being a PITA
Gandalf
As I had to remove the front bumper to replace the intercooler thought I'd replace the faulty sensor, had them switched of as they beeped every time I started the car Censored anyway after replacing it and enabling them I'm getting this error
so what could be causing it
Cheers peter If it ain't broken down it soon will
Pulling my Vanmaster tin tent with my 2005 RED RRS HSE TDV6
1973 Land Rover Series 3 110 safari Gone but not forgotten
1990 Discovery 200Tdi Gone thank god
1996 Discovery 300Tdi sadly missed
2003 Discovery TD5 Gone to LR heaven
2004 Discovery TD5 Gone to Aberdeen hope it likes it there
2005 RRS HSE Rimini Red (my Disco 3 in a posh frock) sadly selling
Think I see a pattern here
Post #555541 Tue May 01 2018 9:20pm
scousefly
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
You say
they bleeped every time you started the car was this after engaging the gears either first or reverse? Reason I ask is aren't they supposed to do that?
Mine are being a pain as well got a continual bleep when put in reverse and flashing light and then they just started working again Big Cry I think its a break in the loom affected by damp but booked in to dealers. Maybe your issue is loom related they are notorious for issues and breaks
Post #555543 Tue May 01 2018 9:31pm
shepp
I had a similar issue after replacing my ac condenser, after removing the bumper. It turned out to be the cable going into the back of the PDC loom connector. I had put strain on the connector and the wire had slightly pulled out of the back of the connector (only by approx 2mm). I just applied pressure and forced the wire back into the connector. I never had another issue with it, i sold it 14month later without an issue. MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #555546 Tue May 01 2018 10:39pm
Eaters
Seems like your test results are telling you the fault - that the earth side of the circuit is foobarred. I wonder if its possible to temporarily connect a wire between the earth side of the sensor loom and a suitable alternative earth just to prove that it is the earth wire and then you can start to search for, and narrow down, where the break actually is. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #555558 Wed May 02 2018 7:57am
x3too
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HST Santorini Black
Looking at the fault it's saying circuit short to ground- That means it will be a chafed wire somewhere rubbing against the body All in my opinion of course but thats wehere I would be looking -
Good luck
Post #555580 Wed May 02 2018 11:59am
Eaters
SORRY. x3too has read this better than me and I concur with this comment and not my own Embarassed Robin
Gone:
MGZTT 190 2.5
Post #555611 Wed May 02 2018 6:48pm
Brit Plumber
Or a + and - wire that have both chafed on possibly a non earthed component such as a sharp edge of the plastic bumper. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #555619 Wed May 02 2018 7:41pm
Gandalf
Well there was me thinking there was a simple fix, I'll just turn them off don't fancy tearing the car apart to find a damage wire beside auto electrics confuse the hell out of me. thanks for the help guys
Peter If it ain't broken down it soon will
Post #555647 Wed May 02 2018 11:16pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
.....until the damage works it's way through the loom to cause more, possibly serious damage
Just a thought. 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #555660 Thu May 03 2018 9:20am
x3too
i agree could be the wires shorted to gether or just the + against ground - I wouldnt be put off fixing it , If you have a cheap multimeter it will help you trace the fault.
Most likely you will find the fault in a obvious place like tight corner or maybe where the bumper has been fixed before .
The PDC loom must plug into the car somewhere close to the bumper , Unplug it from the car and work forwards - I am almost certain the fault will be forward of the connector towards the bumper.
Good Luck
Post #555666 Thu May 03 2018 10:30am
Gandalf
Just a thought.
True It's just that I don't have a problem with mechanical repairs but electronics are a dark art to me, anyway according to the passenger fuse layout fuse No 36 protects the Park Distance Control and Tyre Pressure Monitoring system so I can pull that and isolate that circuit as I don't have TPM. If it ain't broken down it soon will
Post #555671 Thu May 03 2018 1:25pm
