Home > Technical > Bushes query. |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 384 |
Yes i think it was.
Thu Apr 19 2018 6:06pm |
DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264 |
“if you want to contribute to the hire of the garage unit i use and can wait till the 18th May i could do them for you...... “
Sat Apr 21 2018 5:53pm |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 575 |
Better fitting Poly bushes on the new or old wishbones makes a lot of difference |
Sat Apr 21 2018 6:00pm |
I’m under the impression that replacing the whole arm is easier , because sometimes you have to cut the old arm off ?
Sat Apr 21 2018 7:32pm |
it was relatively easy to replace the arms. having a good impact gun is highly recommended!! |
Mon Apr 23 2018 11:38am |
Lower arms aren't usually that bad, it's the uppers that are pretty much always seized and require cutting out, most people replace the whole arm as its easier (and quicker) than replacing the bushes in the old arm and not all that expensive to buy the complete arm.
Mon Apr 23 2018 5:12pm |
Thanks Socast and PC76
Mon Apr 23 2018 6:17pm |
