Home > Technical > Suspension fault
craigzx9
England 2005 Range Rover Sport Supercharged Siberian Silver
Suspension fault
Hi All
Had a battery light on all the time so I've had the alternator replaced and battery light now goes out as should do.
But and big but I now have a suspension fault issue Code reads C1A0054 and if you go over 60mph it comes up Max speed 30mph and the red suspension light is on the dash all the time.
Can anybody please help
Post #554600 Thu Apr 19 2018 5:55pm
PC76
have you checked the voltage of the battery when the engine is switched off?
Also have you done a hard reset? (disconnect battery and leave off for ten minutes. Before re-connecting the battery short the live and negative cables together)
would also be handy knowing which variant you have....
Post #554603 Thu Apr 19 2018 7:02pm
geoffsnook
It's a supercharged as per his pic do you have a red lights on the 4x4 screen when you switch to it Thumbs Up
Post #554606 Thu Apr 19 2018 7:13pm
geoffsnook
Milestone
https://disco3.co.uk/gallery/albums/userpi...nsion_.pdf
Post #554607 Thu Apr 19 2018 7:15pm
Cymruambyth
Wales
Re: Suspension fault
craigzx9 wrote:
Hi All
I`ve had the same issue since I had mine. Very intermittent though. Garage traced it to a CANBUS fault but it needs to get worse before he`ll look for it. Steve.
Post #554608 Thu Apr 19 2018 7:39pm
craigzx9
Hi All
Its a RRS 2005 4.2 supercharged model and yes the red light is on all the time in the 4 x 4 display
thanks
Post #554609 Thu Apr 19 2018 7:49pm
craigzx9
Continuing the saga. had the car checked by LR dealer was told code was suspension control module, but the technician said didn't think it was the module, I fitted a used module and now got error message "Not configured" .
Dose the module need to be configured to the car and if so how or is this a job for the LR dealer.
Also I have no suspension.
Any advice would be appriciated
Post #554879 Mon Apr 23 2018 7:56pm
