Home > General > I have no fuel - apparently! |
There were problems with senders in the fuel tanks in some cars so it could be the sender. Which year is the car - from the photo I can see it is after 2010 facelift but which model year? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wed Apr 04 2018 8:15pm |
kernowkid66 Member Since: 04 Apr 2018 Location: Kernow Posts: 6 |
Hi Tim - it's a 2010 model. |
Thu Apr 05 2018 11:46am |
Ummm, I have reset the ECU. The fuel gauge worked for a few minutes then went back to empty. Is this a classic sign of a sender fault? I would have thought if it was the sender it would either work or not! |
Thu Apr 05 2018 12:38pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4834 |
If you look in My Gallery for file No. 37, you will find a PDF file which can be downloaded if you wish, which may help with your problem as it is a known issue.
Thu Apr 05 2018 10:24pm |
fdhadi Member Since: 17 Feb 2015 Location: Wigan Posts: 180 |
Had the same fault about 6 months ago (2011 RRS). Got the same link from Col and forwarded it to our local Indie. Tank was dropped & sender unit connectors changed. Worked correctly since. Think I was charged about £80. |
Thu Apr 05 2018 11:11pm |
Thank you Col and fdhadi. Very helpful. I'm of to my local garage this morning to see what he says. I shall go armed with this info.
Fri Apr 06 2018 8:43am |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
I had my fuel tank sender wiring modified by the dealers under extended warranty as it was a known issue.
Wed Apr 18 2018 5:50pm |
