Home > Maintenance & Modifications > Scuttle Panel Painting.
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Hi Lads
I have the usual grotty looking Scuttle panel on the 2006 Sport. Just out off curiosity has anyone removed and painted this panel to improve the look.
If so is it easy enough to remove and would it need any special Prep or Paint to do this.
Cheers Jock. Confused
Post #554319 Mon Apr 16 2018 2:56pm
mattdonut
i use autogylm bumper and trim Gel on mine it makes it look a lot better
Post #554333 Mon Apr 16 2018 6:25pm
phillh
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
+1 for Autoglym, it only lasts a few weeks but brings plastics up beautifully. Thumbs Up
Post #554351 Mon Apr 16 2018 9:24pm
Lindab
I have mentioned this before, use Gtechniq C4 Permanent trim restorer for all plastics. Brings it up as new & lasts for around a year or more Thumbs Up
Post #554354 Mon Apr 16 2018 9:32pm
dobbo9
£55 to replace. Mine looks like new now. Oh hang on. It is new!
I must add that I had tried a number of things including smooth peanut butter, but the panel was scratched to hell and almost white. I was happy to spend £55 getting it looking like new.
Post #554364 Tue Apr 17 2018 4:13am
Cymruambyth
Wales
That`s what I`ll be trying next Thumbs Up The Aerospace 303 one did nothing. Steve.
Post #554382 Tue Apr 17 2018 8:45am
Jock 77
Re Scuttle Panel
Hi Lads
Thanks for all the replies ,I had tried a few trim restorers with no luck, but there is a couple mentioned that I haven't ,so will give them a try.
£55 isn't a lot to replace it right enough ,I thought it would have been more expensive. So always the other option. How hard are they to change out.
Cheers Jock. Thumbs Up
Post #554388 Tue Apr 17 2018 9:53am
Lindab
When you buy Gtechniq G4, it comes in a tiny bottle, but a little goes a long way. There is enough to cover ALL the black plastic trim on a Range Rover Sport including the sidesteps with some left over. Your plastic will be like new & it lasts. have a look at Gtechniq website for the application video. You will not be disappointed Very Happy I have no tie-up with Gtechniq but I use most of their products including the ceramic coating which was applied by my accredited detailer Thumbs Up
Post #554404 Tue Apr 17 2018 1:04pm
Jock 77
Re Scuttle Panel
Thanks Lindab. Thumbs Up
Post #554421 Tue Apr 17 2018 3:14pm
RJM16
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Rimini Red
Wiper arms off and pull.
Post #554425 Tue Apr 17 2018 4:24pm
Jock 77
Re Scuttle Panel
Cheers RJM16. Thumbs Up
Post #554543 Wed Apr 18 2018 7:52pm
RJM16
New scuttle from Rimmer Bros.
Post #554598 Thu Apr 19 2018 4:46pm
Jock 77
Re Scuttle panel
Cheers again starting to think more that way. Thumbs Up
Post #554616 Thu Apr 19 2018 8:45pm
I think you need to remove a "A" post trims as well if I remember right, I replaced mine, as for £50.00 thought it was a easier and better job than trying to restore the colour.
Post #554622 Thu Apr 19 2018 9:19pm
Jock 77
Re Scuttle Panel
Cheers Col
Definitely think replacing with new is the way to go. Thumbs Up
Post #554623 Thu Apr 19 2018 9:22pm
