Home > General > handbrake making loud noise when put on |
scousefly Member Since: 24 Jan 2015 Location: sheffield Posts: 248 |
Issue. chances are its probably seized up a bit and will need freeing of and maintaining, hopefully you might get away with a general clean up and adjust but get it into a good specialist |
Fri Apr 13 2018 7:32am |
ashleighash Member Since: 13 Apr 2018 Location: fulham Posts: 25 |
hi thanks for reply i got told it may be the handbrake module ? im so confused in my area not many rr specialist im afraid |
Fri Apr 13 2018 7:36am |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 916 |
As scousfly said,, Epb issues, you will normally experience a loud screech when applying the brake, this is a warning that things will get a lot worse very quickly. Don't use the EPB and get the rear brakes ( handbrakes shoes) serviced as soon as possible otherwise it will cost you dearly. Lots of topics on here about this,, search for EPB. 2010 RRS, TDV8
Fri Apr 13 2018 10:43am |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
I had scraping noise a couple of weeks after buying mine....pads had gone. Long story short, I needed 2 new calipers (both were siezed), discs and pads. While that was done I had my EPB sorted out too as that was making the same noise as yours.
Fri Apr 13 2018 11:04am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2006 |
Take it to an independent specialist like Range Rover London
Fri Apr 13 2018 3:51pm |
Thanks a lot guys I have got it booke in for new back shoes and springs I’m keeping fingers crossed |
Fri Apr 13 2018 9:58pm |
