Home > Tips & Tricks > Side Steps - Protection of Aluminium Trim |
Evo5man Member Since: 04 Jun 2017 Location: Skegness, Lincolnshire Posts: 222 |
I fitted a set of side steps last year and have noticed that the aluminium trim is starting to get marked on the leading edge from stones and road grime thrown up from the front wheels. I have tried various methods of cleaning but decided that some form of protection was required to prevent further damage.
Sat Apr 07 2018 6:04pm |
dobbo9 Member Since: 04 Dec 2011 Location: West Yorkshire Posts: 108 |
Good job. Great solution. |
Sat Apr 07 2018 6:28pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
Yes. Interesting. Just got to get mine in a condition where they’re clean enough to warrant protection. Robin
Sat Apr 07 2018 10:56pm |
PDC Member Since: 13 Dec 2015 Location: Warwickshire Posts: 163 |
I thought that I was the only one that had this problem. They really are a to keep clean!!! 2010 RR 5.0 Autobiography
Sun Apr 08 2018 12:25pm |
I did try some T-Cut and then some rubbing compound which did improve it quite a bit but there are still, what appears to be ingrained marks left. Next step will be fine wet & dry I think Robin 2008 Range Rover Sport TDV8 Gone: Jaguar S-Type V8 4.2 Sport MGZTT 190 2.5 |
Sun Apr 08 2018 12:48pm |
Hi Cymruambyth, Yes, that would definitely be an option to cover the whole length but it is only the leading edge of the aluminium cover trim that seems to be a problem on my side steps. From a visual perspective, it is not obvious that I have only covered the leading edges, I had to take a lot of photos from various angles to get it to show up in the pics! I will monitor the trim over the next 6 months and if necessary, will cover the whole trim length before winter arrives |
Sun Apr 08 2018 12:49pm |
While we are on the subject of sidesteps,,,,ive just replaced mine after having them colour coded last week by a friend who’s a paint sprayer.
Sun Apr 08 2018 3:03pm |
Looks good Andy
Sun Apr 08 2018 3:10pm |
Steve,,mine are aftermarket steps & the trim is only riveted on & is metal not alloy,,so i drilled the rivets out removed had them painted then refitted this morning.I put a coating of Gtechniq C5 on yhem thurs for extra protection
Sun Apr 08 2018 3:21pm |
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 |
A thin coating of ACF50 every few months over 3 years and mine were almost like new when I sold it after 40k miles |
Sun Apr 08 2018 4:48pm |
Just the vents to do black & tint the front windows & all will be good.
Sun Apr 08 2018 5:40pm |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
You`ll need to look out for plod if you tint the fronts Steve. |
Sun Apr 08 2018 6:39pm |
It will be ok,,they will give me a form to take to MoT station after ive removed it to get stamped,,,,,,ive got a mot station
Sun Apr 08 2018 6:57pm |
I think they usually make you take them off at the roadside Steve. |
Sun Apr 08 2018 8:27pm |
