Home > General > LED interior lighting |
This is exactly why i have never done this, because i have never found a quality kit including all the necessary bulbs needed. Hopefully someone will point us in the right direction 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Thu Mar 29 2018 8:43am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8843 |
Powerful UK do a set for the whole vehicle:
Thu Mar 29 2018 10:45am |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
I've just fitted a set of PowerfulUK LED's and they are nice and bright, I'm very happy with the upgrade but mine have only been installed a few weeks so I've no idea on reliability. The light colour is very nice too, it improves the dash in my opinion.
Thu Mar 29 2018 11:04am |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 389 |
As I mentioned in a previous post I bought the full set of LED bulbs from PowerfullUK. The lamp fittings for the door puddle lights and under dash lamps were very loose after fitting and the number plate lamps no matter how hard I tried would not fit as the male connector built into the lamp unit was of bad manufacture and simply would not connect to the car loom. |
Thu Mar 29 2018 12:42pm |
So for me reading here, terrible fit and quality dont bode well for these, if they cant get the fit right i wonder how long the LEDs will last. Think i will pass on Powerful UK 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Thu Mar 29 2018 1:44pm |
This is the kit I was looking at
Thu Mar 29 2018 10:18pm |
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 |
I was thinking this myself. Mine were just bulb replacements so fit perfectly but only seem to last just over 12 months. I would rather change every year than have badly fitting replacements! 2017 SVR. SVO Scafell grey Ebony interior 2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone |
Fri Mar 30 2018 12:57am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
I used these, not cheap but Philips give 12 years lifetime guaranteed for what it's worth, been in 3 years and have not had one fail yet.
Fri Mar 30 2018 1:38am |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
I bought these. The only ones which were the wrong type were the visor ones which didn`t bother me. 6 months on and still ok.
Fri Mar 30 2018 12:37pm |
PDC Member Since: 13 Dec 2015 Location: Warwickshire Posts: 163 |
I can vouch for Powerful UK. I had a full set of interior LED's from them and two years on not a single problem. I know if you look around you can find way cheaper, but you then hear bad reports about them.....
Fri Mar 30 2018 2:19pm |
Hopefully these are better than the ones I have as have just taken a punt and ordered a set. 2017 SVR. SVO Scafell grey Ebony interior 2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone |
Fri Mar 30 2018 6:11pm |
Steve. |
Fri Mar 30 2018 11:50pm |
As mentioned previously the door puddle lamps supplied by Powerfull UK fitted very loosly. Today one partially fell out and gouged the plastic trim which runs along the base of the door opening as the door was being closed. |
Tue Apr 10 2018 4:45pm |
I wonder if thatβs because they are meant for post face lift door cards rather than the pre. Or vice Versa. 2012 5.0 SC AB
Tue Apr 10 2018 5:15pm |
