Home > Faults & Fixes > TDV8 Turbo problem! Split Pipe coming out of MAF box???
glennp123
United Kingdom 2007 Range Rover Sport TDV8 HSE Firenze Red
Hi all
My RRS is driving terrible at the minute. Theres no power like theres no turbos. I have noticed a split on the right hand turbo MAF pipe which goes up to the box on left hand side of engine bay. Is this the problem? It is also leaking some oil.
Post #551666 Sat Mar 17 2018 2:41pm
Disco_Mikey
We may need a little more info...
Down on power all the time?
Intermittently?
Where is the oil leak from?
How much oil has it lost?
Any smoke out the back?
Post #551667 Sat Mar 17 2018 2:52pm
glennp123
Down on power all the time. When started from cold it produced a fair amount of whiteish/blue smoke but then it stopped. Plugged it into computer and it said air flow mass meter and turbocharger.
Then when i came home i noticed this little puddle of oil under the range rover and its came from this MAF pipe which has a split in it.
Post #551672 Sat Mar 17 2018 3:24pm
Disco_Mikey
It does sound as though it has shat a turbo
Time to take off the lower boost hoses, and check for oil...
You will probably find that 5e oil has drained itself from the air filter box, and the filter itself will be soaked with oil
Post #551676 Sat Mar 17 2018 4:17pm
glennp123
No oil in air filter box. Whats the best way to go about replacing this MAF pipe its very tricky when i go down in to where the split is at a bend. Will try attach a picture of what i have at the minute.
Post #551692 Sat Mar 17 2018 9:48pm
glennp123
Post #551694 Sat Mar 17 2018 9:52pm
Disco_Mikey
THat pipe is one piece right around the bottom of the fan cowling. It’s not coming out...
Take the lower turbo hoses off and check for oil
Post #551696 Sat Mar 17 2018 10:09pm
glennp123
I dont really know where to go from here, i need her for work etc. Been in the house since friday afternoon now Crying or Very sad .
Does that plastic pipe coming out of the MAF Sensor not run down into the side of the Turbo then?
and can it be bought new? Its weird the way the car has no power etc and that split is visible now due to the slight leak of oil.. Or is this possibly due to the bearings failed in the RHS turbo and this is oil running out of it.. i dont know and i will have to wait till tomorrow to my mechanic looks at it for me.
Hes just after doing a white RRS with 2 new turbos and it is a big job with body lifted and so on, what a silly silly design by Landrover!
Post #551740 Sun Mar 18 2018 4:26pm
glennp123
This turned out to be the turbos Sad body off chassis job!
2 new recond units sitting waiting.
Doing EGR Deletes as well this time when in.
Also going to do back box deletes to get that V8 ROAR!
Post #552148 Fri Mar 23 2018 10:30pm
Brit Plumber
how do the new MOT rules effect the EGR deletes 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #552156 Fri Mar 23 2018 11:50pm
