Home > Faults & Fixes > leak some cylinder rear side car???
rostan242@gmail.com
I urgently need someone to tell me where the leak comes from it is from the back of the car in the middle
I made 2 pictures it looks like some kind of cylinder from which it gently leaks
and it's hard to find parts for repair without knowing what it is
thanks for any help
Post #551255 Tue Mar 13 2018 9:11pm
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
On what RRS is it do you have ACE
dose it look like part of the anti roll bar
If so your going to be spending around 1200£ 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #551264 Tue Mar 13 2018 9:41pm
rostan242@gmail.com
i have rrs 3.6 v8 2007 what it is ACE and how to check i have?
that leak its from this bottle on first picture
Post #551268 Tue Mar 13 2018 9:51pm
ShooterNeil
Same car as me you have ACE you have Hydraulic anti roll bars and it’s leaking look under bonnet left side by air filter yellow top pot check level you need to keep it topped up till you get it in and fixed
Can’t remember what the fluid is called it’s like power steering fluid 61 AB 5.0 supercharged rocket
Post #551274 Tue Mar 13 2018 10:15pm
ShooterNeil
https://www.googleadservices.com/pagead/ac...amp;adurl= 61 AB 5.0 supercharged rocket
Post #551275 Tue Mar 13 2018 10:17pm
ShooterNeil
Post #551276 Tue Mar 13 2018 10:18pm
rostan242@gmail.com
Is it possible to fix or i need to buy a new part
and if new, you may know a cheap shop
thanks for help
Post #551278 Tue Mar 13 2018 10:20pm
ShooterNeil
Not a part that can be fixed
You need to lift the body to replace it but only the rear about 2”
So don’t get coned when they say it’s a full body off job 61 AB 5.0 supercharged rocket
Post #551279 Tue Mar 13 2018 10:23pm
