Home > Wheels & Tyres > Steering wheel wobble! |
It could be that one of the drive flanges on the front isn't running true, have you recently had a wheel bearing changed in the front ? |
Mon Mar 12 2018 4:41pm |
May be a bad tyre do you know someone with a spare set of wheels and tyres you could borrow |
Mon Mar 12 2018 4:42pm |
StateOfPlay Member Since: 24 Jun 2017 Location: Biggleswade Posts: 26 |
No, no work done on it since purchase and had a full service in August.
It could be the tyres, but it would have done it right from the start (unless a band in the tyre has failed).
Mon Mar 12 2018 4:51pm |
Thanks. Actually, it has had the steering wheel wobble since I purchased it last year. I thought it wasn't right which is why I took it back to them but they assured me there was nothing wrong and the tracking was fine. |
Mon Mar 12 2018 4:53pm |
I would try and find a different set of tyres to try |
Mon Mar 12 2018 4:58pm |
Cheapest possible tyres are never a good option.
Mon Mar 12 2018 5:00pm |
I think they are 107V, they don't have any rating on the tyres themselves. |
Mon Mar 12 2018 6:23pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1936 |
I had this on my first new RRS in 2008.
Tue Mar 13 2018 12:46am |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
Are all 4 tyres the same brand and type? I have a slight wobble on my 12MY and I'm convinced its the odd tyre I have fitted. I'm going to replace it when I get chance. 2012 5.0 SC AB
Tue Mar 13 2018 6:53am |
Kidneywiper Member Since: 07 Feb 2011 Location: England. Posts: 16 |
Are they the correct wheels for the car, ie are they what would have been fitted at the factory at the time of manufacture or are they off of the later new Sport. I recall vibration issues when people started bolting on L322 wheel onto their P38 & Disco 2 cars. The hub spigot hole in the L322 wheel is slightly larger than the spigot on the axle causing the wheel to not be mounted centrally on the axle causing a vibration. |
Tue Apr 03 2018 11:19am |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
The tires may have flat spots or are not round within specs. sometimes it helps to give them a quart or half turn on the rim. RRS 3.0 SDV6 HSE Lux
Tue Apr 03 2018 3:55pm |
