Home > General (L494) > Ghost immobiliser prevents remote climate on app?
tally
i assume remote climate via the smartphone app is not possible if you have the ghost immobiliser installed because the engine needs to be turned on remotely and of course the ghost requires your pin.
can someone with the ghost immobiliser confirm please.
if my assumptions are correct, do you have a method to get around this?
thanks
Post #550805 Thu Mar 08 2018 6:28pm
james5599
That is a good question.
I started mine from the app even though I have the ghost installed. I did it without really thinking about the ghost, it started and ran as intended.
Regards. 2017 Svr and 2018 Svr 😂
Post #550806 Thu Mar 08 2018 7:02pm
tally
I guess the ghost only kicks in when the push to start button is pushed.
Post #550807 Thu Mar 08 2018 7:04pm
tally
now i have ghost installed, i can confirm my suspicions were right.
when i tap the "Engine START 30 min" button on the smartphone, the display gets stuck on "engine starting" and eventually fails after approx 60 seconds.
strange that james doesnt have any problems.
Post #559130 Sat Jun 16 2018 2:19pm
SVR575
Yes it is strange as i have heard all sorts of problems with this Ghost. SVR 2018 in Santorini Black.
Post #559131 Sat Jun 16 2018 3:01pm
james5599
Mine works on my 2017 car- the remote start function that is.
Haven’t tested my 2018 as the ghost isn’t installed yet.
I did recall it throwing up a few faults on the dash afterwards that quickly went away after a minute or 2 though.
I ll try it again tomorrow so I m not imagining it !
Any issues I’ve read about to do with the ghost are usually attributed to poor installation. Fitting to the wrong bus network etc. 2017 Svr and 2018 Svr 😂
Post #559140 Sat Jun 16 2018 4:23pm
tally
Just an update...
Spoke to autowatxh and apparently its not possible to remote climate on 2018 rrs.
Previous years I’m told are fine
Post #559934 Tue Jun 26 2018 2:18pm
mine (Audi S4) could be programmed to either immobilise the cars engine starting or stop the gear box from selecting drive as its a electronic gear box
If you opted for the latter, the engine can start, with out the code, would that not solve the issue (assuming you have eletronic gear selectors)
Post #559937 Tue Jun 26 2018 2:46pm
mannchris
I'd guess that even if it did you would have to stop the engine and start it again, unless the button presses can be input while the remote climate engine is running?
Post #560019 Wed Jun 27 2018 10:28am
the installer said the engine could be running, (manual in my case) and all the functions will work, defrosting the car, but you could select a gear until the code is entered
i've sat in mine and entered code 10 mins later without issue
Post #560020 Wed Jun 27 2018 11:01am
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
