Home > General > lean when cornering and suspension lying down |
james5599 Member Since: 14 Jun 2009 Location: london Posts: 325 |
I had the same fault on an early Range Rover sport - it was diagnosed as the suspension air pump iirc . Car was under manufacturers warranty but it was a 2 grand part as I recall. Same symptoms as you mentioned. But this was 13 years ago so I might not have the exact details correct.
Thu Mar 08 2018 4:38pm |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
Do you mean this light? Steve. |
Thu Mar 08 2018 6:13pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4780 |
first thing to do is change the seals in the front air block . (and clean it out)
Thu Mar 08 2018 7:11pm |
