Home > Wheels & Tyres > New rims |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4816 |
Why not just buy another set of sensors and fit to the new rims ?, or alternatively as the TPMS system in a RRS1 is pretty useless anyway, why not just de-activate it in the CCF files.
Tue Mar 06 2018 7:00am |
Hamtheman Member Since: 18 Jan 2017 Location: Joburg Posts: 33 |
Yup was thinking along the same lines, TBH the TPMS on my RRS (2011) is pretty much spot on with no errors.
Tue Mar 06 2018 7:09am |
The car should recognize the new sensors automatically, If I remember correctly just fit the wheels leave the car for a few minutes, then drive car and once you have done a few Km's over 20mph it will automatically code them. When you fit the new sensors make a note of the serial no. of each one and wheel position so if there is a problem you can get them coded to the car using a diag. tool.
Tue Mar 06 2018 7:41am |
Thanks Col, the TPMS here is the same here, no actual reading just a warning on low pressure . I like that as on a long gravel road it warns you of an issue before you completely destroy the tyre. |
Tue Mar 06 2018 8:16am |
