Home > Technical > Advice on cold start problem 2006 RRS 2.7 |
Ch04oma Member Since: 07 May 2017 Location: Huddersfield Posts: 16 |
Sounds like glow plugs mate as myn does it. Your best getting a fbh kit as the glow plugs are a nightmare to get out if they do |
Mon Feb 26 2018 10:21pm |
adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110 |
My car did exactly that, fire and stall. You can try 3 or 4 full cycles of the glow plugs before turning the key see if that helps. Wait for the light to go and repeat. My problem persisted and indy suggested fbh over glow plugs. Not a problem starting since. Just have to remember to warm the car 20mins before, yes it working round a fault but for the odd days we get cold snap I am happy. |
Tue Feb 27 2018 6:59am |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
No idea if the 2.7 is the same Adam, but with a TDV8, cycling the ignition is a pointless exercise. The glowplugs stay energized despite the light going out on the dash and remain on for a time even after the car has started.
Tue Feb 27 2018 9:10am |
Deegan Member Since: 04 Jul 2017 Location: Kent Posts: 9 |
Excellent thanks to all of you for the replies.
Tue Feb 27 2018 1:30pm |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1133 |
Tue Feb 27 2018 1:52pm |
Thanks for that informative reply. I have a few days off so will read up on fbh thanks.
Tue Feb 27 2018 1:56pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8798 |
"FBH" is the fuel burning heater that helps the engine warm up in cold weather. It can be made to turn on early and start warming the coolant. This helps with cold starting as it warms the engine slightly.
Wed Feb 28 2018 11:26am |
