Home > Wheels & Tyres > Any issues with fitting 295/40/22 on a L494 2016 HSE
cubbyno9
I have just bought a set of alloys and the seller says for the wheel size fine to use 295/40/22. Is there any issue fitting to a 2016 HSE.
Been reading various threads and getting conflicting views, thanks in advance for guidance. 2017 Range Rover Sport HSE
Post #549531 Fri Feb 23 2018 6:37pm
Tyrefitter
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
I had a set of 295/40r22’s on my14 AB with no problems.ive now got them on my Amarok pickup but I’m thinking about getting the wheel powder coated black & fitting them on my14sc,,the svr has the same size tyres.
Andy 2014 RRS SC santorino,coris roof.
2016 VW Amarok Highline,candy white
2014 Evoque D-Lux Fuji
Previous motor.
2014 RRS AB FUJI
2012 RRS Dynamic red edition Fuji
2012 RRS SE santorino
2015 Navara White
2008 RRS white TDV8
2007 RRS black TDV8
2002 RR Vogue
1996 P38 2.5 HSE.
Post #549536 Fri Feb 23 2018 6:58pm
Tyrefitter
These are the alloys I have.
Previous motor.
2014 RRS AB FUJI
2015 Navara White
2008 RRS white TDV8
2007 RRS black TDV8
2002 RR Vogue
1996 P38 2.5 HSE.
Post #549537 Fri Feb 23 2018 7:00pm
cubbyno9
Cheers Andy. Getting them fitted today so will see how it goes.
Do I need to change wheel alignment etc? 2017 Range Rover Sport HSE
Post #551350 Wed Mar 14 2018 3:01pm
Tyrefitter
No,,just fit the tyres/wheels.you only need alignment doing if you've altered suspension or fitted new suspension components.
Previous motor.
2014 RRS AB FUJI
2015 Navara White
2008 RRS white TDV8
2007 RRS black TDV8
2002 RR Vogue
1996 P38 2.5 HSE.
Post #551352 Wed Mar 14 2018 3:22pm
cubbyno9
Hi, sorry for delay getting back.
The alloys I have are deep dish (I think that's what its called) and when trying to fit they are catching on the brake caliper. To confirm my car is a 2017 HSE.
Spoke to the chap I bought the wheels from and he suggests using a 5 mm spacer as that will clear it. Not sure of the actual wheel size as such, but the tyres are 295/40/22.
Looking for a bit of advice, would the deep dish wheels cause any problems.
I have seen other RRS with 22inch alloys so I know its no issue with the size of wheel however I am apprehensive with the wheel type and using spacers.
Craig
Post #552081 Thu Mar 22 2018 11:02pm
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
