Home > Maintenance & Modifications > Fault Code Help
geoffsnook
The cruise issue will more than likely the wiring loom in the steering wheel itself a common problem and not expensive to get look on the bay find one pop airbag off and refit simples you will need a airbag release tool or a coat hanger which ever you prefer do a search on here for cruise problems Thumbs Up
Post #549284 Tue Feb 20 2018 3:21pm
map_rrs
So IID BT tool arrived this morning - thanks to BAS for the prompt service - set it up and took a look at the live readings for the injectors.
At idle I get these results:
What are people's views on these results?
When I apply some throttle I get these numbers at 1300rpm or thereabouts and the readings remain static:
What might this mean?
Also read the Fault Codes and can see that as well as the ones I knew about also got:
P0578-00 Speed Control multi function input A circuit is stuck - this ties in with @geoffsnook's comment Thumbs Up
I'll continue to monitor the injector readings whilst using cleaner to see if the numbers improve with mileage.
That said any advice based on your experience is gratefully received.
Post #549357 Wed Feb 21 2018 2:25pm
geoffsnook
Cylinder 1 is way low and 5 seems to be compensating for it Thumbs Up
Post #549367 Wed Feb 21 2018 4:39pm
map_rrs
Thanks - will continue with the injector cleaner and watch to see if the figures improve.
In terms of the numbers at 1300rpm - what does that mean? Is it normal or not?
map
Post #549368 Wed Feb 21 2018 4:43pm
geoffsnook
yes normal as normal is Rolling with laughter Thumbs Up
Post #549369 Wed Feb 21 2018 4:45pm
