Home > Technical > 2008 Range Rover Sport Death Wobble |
Easiest way is if you know someone else with same car & swap wheels over.
Sun Feb 18 2018 7:08pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 384 |
I had a wobble at speed turned out to be the brakes binding, got them replaced on under warranty from the garage i purchased it from. |
Sun Feb 18 2018 7:17pm |
Agree that sounds like binding front brake. I had the same on my old Jeep Cherokee. Completely out of the blue experienced the shaking quite violently. Easy to tell if you stop and feel the wheels the offending side will be hot and/or terrible smell of overheated brake pads.
Sun Feb 18 2018 8:18pm |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
Yep, me too. Shortly after buying my car after it had been sat on a forecourt for a good few weeks. The chronic shaking turned out to be a binding o/s rear brake calliper and a binding n/s front. Only discovered after an episode of this shaking, pulled over and felt the very hot wheels. A new rear calliper and new pistons/seals in the Brembo front... problem sorted. |
Sun Feb 18 2018 8:31pm |
Xrover Member Since: 08 Feb 2018 Location: Palm Desert Posts: 31 |
I don’t have access to another set of 19” Wheels/Tires. Interesting info about the brake calipers binding. I’ll keep my temp gun in the car and check the brake temps next time it happens.
Mon Feb 19 2018 1:17am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
If you have replaced/rebuilt the front suspension, then I hope you have had a "proper* Wheel Alignment. Excessive Toe-out or Toe-in can cause a serious shake. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Mon Feb 19 2018 10:15am |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
Have you swapped tyres front to back? Some tyres get wear that can cause issues ( my Uniroyals for one) and whilst the shaking issue is not the same symptoms as mine, its an easy and cheap check to just eliminate this as a possible problem. They would still balance OK but on the road would throw up issues when under load.
Tue Feb 20 2018 10:18am |
UPDATE:
Sat Mar 03 2018 6:07pm |
Glad you got it sorted and relatively easily. It’s a shame that some “automotive specialists “ aren’t.
Sat Mar 03 2018 6:16pm |
