Home > In Car Electronics > DRL fitment and wiring |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4779 |
most cars don't have an ignition live at the headlight (despite some bloke from Oz keep saying there is).
Thu Feb 15 2018 1:13pm |
Thanks for the reply Andy,
Thu Feb 15 2018 1:31pm |
DRL controllers seam to have changed since the last time I looked.
Thu Feb 15 2018 6:42pm |
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 |
On my old RR I fitted drill rings.
Thu Feb 15 2018 8:42pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4835 |
At no point do I recall saying all cars have the ignition live in the headlamp, all I know is my cars did, both pre-facelift and facelift variants because I used it to fit DRL's to the pre-facelift. As never having had a lower spec. car that did not have AFS I wouldn't pretend to not know one way or the other. So the consensus is if you have AFS you have the live Pin No.14, if not you don't. P.S I don't live in OZ, the flag is actually NZ hence Hawkes Bay NZ. Cheers Col |
Thu Feb 15 2018 10:06pm |
Best way to off a Kiwi, call him an Ozzie |
Fri Feb 16 2018 10:48am |
Well I ordered some flexible drl strips to see what they are like.
Fri Feb 23 2018 4:20pm |
Quick update:
Tue Mar 13 2018 12:29pm |
jzive Member Since: 23 Feb 2014 Location: Essex Posts: 80 |
Pls post pic when done. |
Tue Mar 13 2018 1:14pm |
I only had to wire up 2 wires (as my post above) led drl rings lit up instantly as they should, no delay in brightness etc, still going well 1 year on |
Tue Mar 13 2018 1:20pm |
I don't think you understand what I'm trying to achieve. The delay in brightness is by design..
Tue Mar 13 2018 2:45pm |
No problem, was just trying to be helpful.
Tue Mar 13 2018 3:22pm |
I didn't mean to come across as rude and apologise if I did. |
Tue Mar 13 2018 3:43pm |
No need to apologise, not offended at all.
Tue Mar 13 2018 9:25pm |
