Home > Maintenance & Modifications > Cleaning Side Steps
Chas9
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Alaska White
Post #548444 Tue Feb 13 2018 3:47am
Chas9
Post #548445 Tue Feb 13 2018 3:48am
Chas9
3m carbon fibre wrapped chrome trim
Post #548446 Tue Feb 13 2018 3:48am
SRE
So much better in Black. Bow down Thumbs Up In Spain - 2018 F Pace - Down and out's Velar
In UK - Not saying, but its NOT a Muddy Milk Float.
Gone - A couple of RRS, A couple of Disco's. Plus loads of cars, some I'm too ashamed to mention.
Post #548469 Tue Feb 13 2018 9:44am
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
As others have suggested, give them a good clean with Autosol but using a tooth brush on the areas around the top edge.
Once you are satisfied with the finish coat them with some AFC50. It is a protector/anti corrosive substance originally used in the aero industry. I did this with mine and maintenance afterwards was just a once a year quick clean up and re-coating since the AFC50 does diminish over time with them being so exposed
Post #548473 Tue Feb 13 2018 10:28am
JordLMW
United Kingdom 2008 Range Rover Sport TDV8 HST Sumatra Black
Sorry guys only just managed to catch up on the thread! Thanks alot for all your suggestions, I'll see if I can get some autosol on them and try give them a polish up, they are just the original aliminum steps that came with the car, if all else fails I will look at having them powder coated I think.
Thanks a bunch for the replies always helps when you have a good forum! Top marks!
Regards,
Post #548745 Thu Feb 15 2018 7:29pm
GodivaNige
England 2009 Range Rover Sport TDV8 HSE Buckingham Blue
After reading this thread, popped into Halfords today and bought cheap acid based wheel cleaner as the ally trims on the sidesteps on my car were looking shabby and stained.
Using one of those washing up sponges that have scotchbrite on one side, I soaked it in the fluid and applied a liberal coat on to the strip, then using the scourer side of the spong, gave the strip a scrub. Washed it all off with a water soaked cloth.
Came up like new and was very easy to do.
Will give them a polish next then apply a sealer.
£5 for Turtle Wax wheel cleaner, contains sulphuric acid so I used latex gloves, didn’t fancy acid burns on my hands Neutral Thumbs Up
Post #548753 Thu Feb 15 2018 8:19pm
Bustanut
+1 for this, acid based wheel cleaner brought them up a treat. Now got a coat of sealant on them so see what they are like next wash.
Post #549200 Mon Feb 19 2018 7:53pm
Eaters
What sealer do you use? Robin
Awaiting rebuild: NGTF
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #549234 Tue Feb 20 2018 7:47am
GodivaNige
I used Wonder Wheels wheel sealer. Didn’t spray directly on to the strip, I soaked a cloth with the spray and did one single wipe along the aluminium. It takes a long time to go off so best not applying it when it’s about to rain, apply under cover if you can.
The product has rave reviews on lots of websites, Auto Express for example. I use it on my wheels and it is very good, lasts a long time.
http://www.autoexpress.co.uk/accessories-t...alant-2017
Post #549248 Tue Feb 20 2018 9:27am
Bustanut
I have tried GYEON Q2M Wet Coat this time as I used it on the rest of the car for speed and ease of use. I plan to machine polish the whole car in the next month or so and will use Gyeon Mohs once that’s done.
Post #549303 Tue Feb 20 2018 6:44pm
