Home > General > Rear prop
geoffsnook
Rear prop
Hi i have a rumble when i am accelerating i assume its the rear prop bearing as i have done some searching on subject are the props the same part number for the all the sports or do i need to get one specifically for my supercharged Thumbs Up
Post #547995 Wed Feb 07 2018 9:16pm
GodivaNige
England 2009 Range Rover Sport TDV8 HSE Buckingham Blue
Have you crawled underneath and checked it? The centre bearing itself isn’t usually the issue but the bonded rubber surrounding it which perishes and breaks up. If you can get underneath (don’t forget to support vehicle, just in case the suspension drops from offroad height of its own accord Thumbs Up ) and grab the propshaft giving at a good push and pull, it’s obvious if there’s a problem. Lots of play and feels lose in the carrier. A torch and an inspection mirror to view the rubber around the bearing is a good idea too.
Post #547996 Wed Feb 07 2018 9:31pm
Rear props all the same LR037028 over £400.00 from L/R though.
Post #547997 Wed Feb 07 2018 9:34pm
£275 for a GKN one from Advanced Factors:
https://www.advancedfactors.co.uk/tvb50039...0801-p.asp
Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #547999 Wed Feb 07 2018 9:56pm
Gandalf
Had the same symptoms the dealer I bought it from is replacing it at his expence If it ain't broken down it soon will
Pulling my Vanmaster tin tent with my 2005 RED RRS HSE TDV6
1973 Land Rover Series 3 110 safari Gone but not forgotten
1990 Discovery 200Tdi Gone thank god
1996 Discovery 300Tdi sadly missed
2003 Discovery TD5 Gone to LR heaven
2004 Discovery TD5 Gone to Aberdeen hope it likes it there
2005 RRS HSE Rimini Red (my Disco 3 in a posh frock)
Think I see a pattern here
Post #548001 Wed Feb 07 2018 10:41pm
geoffsnook
just had a look cant really see its perished well from what we saw but can move the prop quite a lot inside the rubber mount Thumbs Up
Post #548048 Thu Feb 08 2018 6:16pm
geoffsnook
Also just noticed whilst swmbo was was reversing i could here what sounded like a universal joint type of clunk from behind the drivers wheel wondering if its the front prop that has a problem Whistle
Post #548049 Thu Feb 08 2018 6:24pm
More likely to be the CV joint on the half shaft. If it's had a split gaiter replaced then there is likely to be wear in the joint. I had a split gaiter replaced on my TDV8 and the CV joint started making noises a good 2 years later... 2012 SDV6 - it's missing a couple of cylinders
Post #548065 Thu Feb 08 2018 8:58pm
geoffsnook
Thanks taking it back to garage tomorrow had not heard the clicking nefore bit it did sound like a Uk joint not moving properly Thumbs Up
Post #548070 Thu Feb 08 2018 9:05pm
geoffsnook
Well been back and it does appear to be the front off side driveshaft that is making the noise even though we could not make it do it whilst on the ramp so a new complete shaft ordered and should be here Monday Thumbs Up
Post #548118 Fri Feb 09 2018 6:28pm
