Home > General (L494) > Dust Caps |
Violetpiano Member Since: 03 Jun 2014 Location: London Posts: 561 |
Please don't shoot me as this is probably a daft laddy question.
Mon Feb 05 2018 11:08pm |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 527 |
Only advice is make sure whatever you fit is plastic! Metal ones will react with the valve housing and seize on...if you try and remove them by force they will snap the valve and the whole TPMS units have to be replaced at considerable cost! |
Tue Feb 06 2018 12:03am |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
As above, they don’t play any part in TPMS.
Tue Feb 06 2018 12:21am |
Thanks all. Will bear in mind to get plastic ones - but are the ones that LR sell not metal?
Tue Feb 06 2018 1:31pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
Plastic 16MY Estoril Blue SVR.............
Tue Feb 06 2018 1:43pm |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1826 |
Jas, i bought black metal Range Rover ones from ebay . Nice finishing touch imo.
Tue Feb 06 2018 3:17pm |
Thanks. Will try to find plastic ones elsewhere but if I can't get the expensive LR ones. SVR575, do read the comments above about using metal dustcaps Cheers Jas Current RRS: MY18 SVR Previous RRS: MY15 RRS 5.0L Autobiography |
Tue Feb 06 2018 3:39pm |
I dont like the plastic ones and i have never had a problem with them. SVR 2018 in Santorini Black. |
Tue Feb 06 2018 3:45pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4835 |
If you use metal one's just make sure they are stainless steel, no problems then have used them for years.
Tue Feb 06 2018 10:08pm |
I’ve never had problems previously with metal ones but my previous valves were brass and rubber... the tpms valves are made of soft metal presumably aluminium.. if you don’t pre grease them they will corrode and fuse together..
Tue Feb 06 2018 11:57pm |
I am going to stick with Farmer Chalk's advice. Last thing I want is to get stuck in the South of France with the valve shearing when going to check or put air in tyres!
Wed Feb 07 2018 6:08pm |
Funnily enough - I recall reading on a forum about metal valve caps getting seized and thinking - "weird never seen that happen'.
Wed Feb 07 2018 7:13pm |
