Home > Maintenance & Modifications > Cheap fix for GPS Aerial. |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
Thank you flack!
Wed Dec 20 2017 12:32pm |
ChrisKT Member Since: 02 Oct 2017 Location: Exeter Posts: 4 |
Hi all.
Sun Feb 04 2018 10:27pm |
wilchesth Member Since: 11 Mar 2018 Location: Falmouth Posts: 41 |
I had the same problem as everybody else with the GPS icon crossed out in red. I decided to buy an antenna as per Flack’s post and tried it first by connecting it directly to the back of the navigation unit and put the antenna by the window. Disconnected/connected all the cables first to give it a “reset”, did a location calibration and drove around for about half hour and the GPS icon is still crossed out in red and the location in the map is miles away from where the car is.
Tue Mar 20 2018 11:17am |
Just in case anybody has the same issues as me here is an update to my problem ^^^.
Wed May 09 2018 3:50pm |
Bustanut Member Since: 19 Nov 2017 Location: Nottingham Posts: 71 |
Does anyone know what unit to buy if you have problems with phone and DAB signal (interference when the door opens on the DAB and really poor crackly phone reception). I'm assuming its the same procedure just with a different type of aerial. Also after having a rummage around under the roof lining yesterday i couldnt get the connectors off. Does anyone have any pointers for this please.
Mon Mar 04 2019 12:28pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
Can somebody post an up to date link to the cheap GPS unit to purchase. I’ve got code B1A89-11(6c) Satellite Antennae - general electrical failure - circuit short to ground. Found this thread via the search. 2006 2.7 TDV6 HSE in Cairns Blue. |
Wed Mar 18 2020 4:13pm |
Try this one
Wed Mar 18 2020 4:29pm |
Devon Z Member Since: 22 Sep 2019 Location: Brixham, Devon Posts: 313 |
Just done this job on mine, bought the cheapest sat nav aerial on eBay (£4) didn’t matter what connection as I reused mine. Very straight forward job.
Wed Mar 18 2020 8:06pm |
Thanks 2006 2.7 TDV6 HSE in Cairns Blue. |
Wed Mar 18 2020 9:20pm |
I did this today having purchased an aerial from the link wilchesth posted having reduced the price to £4.99 posted!. Anyway followed the guide which was great but I took a couple of photo’s that may add to those already posted. The only issue I found with mine not mentioned is when I took the locking bit from the Fraka connection I couldn’t withdraw the cable. Looking down the barrel of the gun as such there was a little plastic lug, which I freed using an instrument screwdriver and bingo. It all works again and the only thing is all my securing clips (3) for the NSR boot panel were crushed, so I’ll have to order some of those yellow locating clips. Sorry for the poor photo’s but you get the idea. My base plate was rusty and the inside of the shark fin had condensation in it. All in all took me and hour and a bit but I am a bit James May on the speed front.
Mon Apr 06 2020 3:31pm |
Tomtun Member Since: 05 Oct 2021 Location: Aberdeenshire Posts: 2 |
Hi Flack,
Tue Oct 05 2021 3:09pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
If its just to test for a few days, put it in the front windscreen.
Tue Oct 05 2021 6:51pm |
