Home > General (L494) > CTEK Battery Sense & CTEK MXS5 |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1289 |
Sun Feb 04 2018 11:14am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
Not sure about this but does the RRS2 not have a AGM batteries ?, as I didn't think the Recon Mode will work on a AGM battery.
Mon Feb 05 2018 11:45am |
Lindab - thank you.
Mon Feb 05 2018 12:57pm |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
I just read that smartcharger.com link and on the very last question, the answer states this - "If you have normal wet batteries (not GEL or AGM) remember to RECOND both when you take the boat out of water and put it back in."
Tue Feb 06 2018 1:03am |
This is what I was looking at, as it was "greyed" out and no specification made me think perhaps it didn't work on the AGM's.
Tue Feb 06 2018 1:50am |
I think that the greyed our box implies that in AGM (only) mode; it won’t run the recon cycle. 2022 P440e AB |
Tue Feb 06 2018 8:13am |
That's how I see Col's scan aswell, the recon will only run the cycle when in recon mode. But if you check the voltage value's through the cycles, in step 4 the 14.4V for standard battery is the same as the recon mode, whereas AGM goes up to 14.7V. But does it matter, as step 1 goes to 15.8V on each mode? Does the RRS charging system not go over 15V at times?
Tue Feb 06 2018 10:36am |
Have to admit still not sure one way or the other as there is this Charging Programs Explanation as well, as it adds step 6 to normal battery programme, no mention of AGM programme. I suppose could always email ctek and ask the question for a definitive answer.
Tue Feb 06 2018 11:16am |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
Some experts say not to use the recon mode on AGM batteries. The high current would damage it. RRS 3.0 SDV6 HSE Lux
Tue Feb 06 2018 4:47pm |
Thats the thing... There are alot of "experts / keyboard warrirors" out there.
Tue Feb 06 2018 8:00pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 869 |
Hog is saying the high current on recon mode can damage the battery. I cant see that as there is no high current. Going by the manual on recon you are boosting the voltage to 15.8V but the current to do this is 1.8amps. This is an extra boost to the voltage at step 3 (bulk) which at any setting, (AMG, RECON, or AMG+RECON) takes the battery up to either 14.4V or 14.7V all at 5amps. If the recon is chosen, it then takes it up to 15.8V at 1.8amps but it is over a 2 or 6 hour timescale. It then sits at float only monitoring the battery, but if it drops too low, the charge cycle restarts |
Tue Feb 06 2018 8:51pm |
I did not mean the amps , but the high volts. The recon mode is triggering gassing. And even CTEK warns to do this not more than once a year. with AGM batteries. So there seem to be some truth in the concerns of some other experts. RRS 3.0 SDV6 HSE Lux
Tue Feb 06 2018 9:07pm |
Is it possible not all ctek chargers have this facility, I have a MXS10 and there is no mention of a AGM Recon mode in the user manual, however there would appear to be two different MSX5 models, one being called MXS5 Test & Charge the other just called a MXS5 and reading the manuals one appears to have this facility the other does not, as PauloAmore said I can't believe ctek would have this option if it did not work or there was a possibility of it damaging the battery.
Tue Feb 06 2018 9:32pm |
AGM batteries due to their construction are sealed and therefore do not gas like a lead acid battery
Wed Feb 07 2018 12:01am |
