Home > Technical > Warning Lights just come on
Tricky Micky
United Kingdom 2007 Range Rover Sport TDV6 HSE Santorini Black
Good morning all
I have only had the RRS 2007 for 2 weeks and on a long drive to Somerset on Friday i had 3 warning lights come on all yellow , the hand break sign the ABS and then the picture of the car with arrows pointing left and right, when theses come on it cut out the cruise control and the lights on the suspension raiser bottom went out, i stopped turn the key off restarted the car and then it cleared all the lights , 5 miles later they all come on again , this was my trip round Somerset Friday / Saturday every so often the light come on . i must say it did not in any way alter the drive or stability of the car , it was just bloody annoying.
Any help would be grateful on the cause
Thank you
Post #547023 Mon Jan 29 2018 8:40am
Cymruambyth
Wales 2006 Range Rover Sport Supercharged HST Zermatt Silver
Ideally you need the fault codes read.
Is this the one you mean with the arrows?
If so it`s the dynamic response warning. Might be worth checking the level of the fluid in the reservoir located below...
When mine comes on (red) it tells me to slow to 30mph and it drives like a clown car....very annoying. Steve.
2006 Zermatt Silver, Range Rover Sport HST 4.2 Supercharged on 22" Stormer Alloys.
Post #547102 Tue Jan 30 2018 11:40am
Tricky Micky
yes that's the one , but also 2 more come on first , it only happens on long trips and normally when i apply the breaks , i have come back from Somerset and my wife has the car and has had no warning lights at all come on since . but thank you for the reply and i will check the levels tonight
Post #547105 Tue Jan 30 2018 11:56am
Paddi
Quote:
it only happens on long trips and normally when i apply the breaks (sic)
It is quite common for the brake light switch to cause problems of all sorts. The switch with time, suffers from arcing and carbon build up internally. The part is about £15 and takes 10 minutes to change. Worth a try?
How to is here:
http://www.rrsport.co.uk/forum/topic30757....ght+switch
PS. - You should also check the stop and tail bulbs are good quality (Osram) both working properly and there is no corrosion in the bulb holder. 2008 MY Java Black TDV8 HSE
Post #547107 Tue Jan 30 2018 12:15pm
Tricky Micky
Paddi , what a good post thank you for this it sound just like the faults i am having to be honest , i will try this fix once i location a switch, great thank you
Post #547109 Tue Jan 30 2018 12:29pm
Cymruambyth
How to is here:
Great "how to" Thumbs Up Steve.
Post #547121 Tue Jan 30 2018 1:50pm
m3nutter
England 2007 Range Rover Sport TDV6 HSE Zermatt Silver
I had exactly that recently , changed the brake light switch dead easy, all sorted now Thumbs Up
Post #547418 Fri Feb 02 2018 8:12pm
Cymruambyth
I don`t understand how a brake light switch issue would cause a dynamic response warning light Confused Got me thinking that this may be my problem. Steve.
Post #547461 Sat Feb 03 2018 8:37am
m3nutter
Hi mate I think it’s simply the fact that the contacts in the two switches in the pedal switch start to arc and cause volt spikes and things in the electrical system which just make it confused
Post #547479 Sat Feb 03 2018 9:47am
Cymruambyth
Ah right Thumbs Up Steve.
Post #547526 Sat Feb 03 2018 4:49pm
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
