Home > Technical > Warning Lights just come on |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
Ideally you need the fault codes read.
Tue Jan 30 2018 11:40am |
Tricky Micky Member Since: 22 Jan 2018 Location: Chester Posts: 9 |
yes that's the one , but also 2 more come on first , it only happens on long trips and normally when i apply the breaks , i have come back from Somerset and my wife has the car and has had no warning lights at all come on since . but thank you for the reply and i will check the levels tonight |
Tue Jan 30 2018 11:56am |
It is quite common for the brake light switch to cause problems of all sorts. The switch with time, suffers from arcing and carbon build up internally. The part is about £15 and takes 10 minutes to change. Worth a try? How to is here: http://www.rrsport.co.uk/forum/topic30757....ght+switch PS. - You should also check the stop and tail bulbs are good quality (Osram) both working properly and there is no corrosion in the bulb holder. 2008 MY Java Black TDV8 HSE |
Tue Jan 30 2018 12:15pm |
Paddi , what a good post thank you for this it sound just like the faults i am having to be honest , i will try this fix once i location a switch, great thank you |
Tue Jan 30 2018 12:29pm |
Great "how to" Steve. |
Tue Jan 30 2018 1:50pm |
m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 141 |
I had exactly that recently , changed the brake light switch dead easy, all sorted now |
Fri Feb 02 2018 8:12pm |
I don`t understand how a brake light switch issue would cause a dynamic response warning light Got me thinking that this may be my problem. Steve. |
Sat Feb 03 2018 8:37am |
Hi mate I think it’s simply the fact that the contacts in the two switches in the pedal switch start to arc and cause volt spikes and things in the electrical system which just make it confused |
Sat Feb 03 2018 9:47am |
Ah right Steve. |
Sat Feb 03 2018 4:49pm |
