Home > Tips & Tricks > Disabling keyless entry- it works!!!!
Buckster
Not sure if this works with our cars but there has been success over on the Disco forum, considering the number of cars being stolen recently using keyless signal boosting I thought it was worth a post over here Thumbs Up
https://www.facebook.com/lespotts4wheeldri...f=mentions 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, 19"s on Goodyear Duratracs, ARB fridge, TuffTrek awning 😎
Post #546223 Thu Jan 18 2018 9:40pm
Ratkat
Top tip, worked a treat on my MY16 AB. Bit of a shame as keyless entry is really convenient but better to keep it safe! MY16 RRS Autobiography Dynamic, Firenze red, black pan roof, satin black 507's with satin black stealth pack, ebony and ivory interior.
Post #546239 Fri Jan 19 2018 8:18am
PEACHY
+ 1 Great tip Thumbs Up 14MY Autobiography Dynamic - SDV6 - Fuji White Smile
Post #546241 Fri Jan 19 2018 8:49am
Tyrefitter
Great tip & saved me £300 fitting the Ghost Autowatch.
Andy Andy.
2015 RRS AB Fuji.
2014 Evoque D-Lux Fuji.
Previous motor.
2014 RRS SC Santorino,coris roof.
2016 VW Amarok Highline,candy white
2014 RRS AB FUJI
2012 RRS Dynamic red edition Fuji
2012 RRS SE santorino
2015 Navara White
Subaru wrx sti widetrack
2008 RRS white TDV8
2007 RRS black TDV8
2002 RR Vogue
1996 P38 2.5 HSE.
Post #546242 Fri Jan 19 2018 8:56am
Tyrefitter
Just tried on my14 RRS,,it works but you need the ignition on for it to work Thumbs Up Thumbs Up
Andy Andy.
2015 RRS AB Fuji.
Previous motor.
2014 RRS AB FUJI
2015 Navara White
2008 RRS white TDV8
2007 RRS black TDV8
2002 RR Vogue
1996 P38 2.5 HSE.
Post #546243 Fri Jan 19 2018 9:00am
hafman
At the risk of exposing my stupidity, I thought that using keyless entry / exit was more secure than using the fob buttons, as no radio waves can be caught / cloned. Embarassed Embarassed Embarassed
Post #546244 Fri Jan 19 2018 9:03am
Tyrefitter
That true but I'm hoping they cannot clone it when near car to open it,,if you get my drift.
Andy Andy.
2015 RRS AB Fuji.
Previous motor.
2014 RRS AB FUJI
2015 Navara White
2008 RRS white TDV8
2007 RRS black TDV8
2002 RR Vogue
1996 P38 2.5 HSE.
Post #546245 Fri Jan 19 2018 9:06am
d-9
How do you think the key talks to the car?
Post #546309 Fri Jan 19 2018 11:06pm
I never use the Fob to Lock or Unlock the car, as I thought I read some where that if you use the door handle buttons then no radio signal is transmitted, but could be completely wrong on that.
Post #546318 Sat Jan 20 2018 8:42am
d-9
Unless you physically put a key in the hole and turn it, the key has to be talking to the car with some kind of wireless radio magic.
Post #546319 Sat Jan 20 2018 8:59am
fkarim
Correct. However, I believe (and I may be wrong but I read it on this forum) when using the buttons on door handles the radio signal is very weak, much lower range. A thief would have to be standing right next to you to clone that one.
Like hafman, I am also unsure whether using the key fob buttons instead of the door handle buttons is a good idea when you’re, say, in a car park with someone waiting nearby to clone the signal. At home, I avoid leaving the keys close to the driveway to minimise the risk that keyless entry exposes us to. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory
Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond
Post #546321 Sat Jan 20 2018 9:19am
"Correct. However, I believe (and I may be wrong but I read it on this forum) when using the buttons on door handles the radio signal is very weak, much lower range. A thief would have to be standing right next to you to clone that one."
That maybe what I was thinking of.
I really wouldn't know how it all works, but you can lock/unlock the car from several meters away using the Fob, but to unlock or lock the car using the door handle buttons the Fob itself has to be within about a metre of the car otherwise the car just "beeps" at you, so on that basis I guess it is a weaker signal of sorts.
Post #546322 Sat Jan 20 2018 9:20am
Dobby
My local dealer carried out THIS fix on mine. They made sure only two keys were programmed to the car, and also said the 'modification' mentioned in the link prevents the keyless relay attack.
Post #546828 Fri Jan 26 2018 3:44pm
